High CPU Usage: My Computer Struggles To Run Multiple Programs
The discussion revolves around a user's experience with high CPU usage on their laptop, which struggles to run multiple programs simultaneously. Participants explore potential causes and solutions, including hardware upgrades, software reinstallation, and system maintenance practices.
  • The original poster reports high CPU usage and frequent crashes, particularly when running programs like AIM, MSN Messenger, and Firefox.
  • Some participants suggest that a RAM upgrade could improve performance.
  • Reinstalling Windows is proposed as a potential solution, though the original poster expresses uncertainty about how to do this.
  • Another participant notes that the laptop has been slow since it was returned from Dell, implying a possible hardware or software issue related to that service.
  • Concerns are raised about spyware and adware affecting performance, with suggestions to clean out such programs and check the registry.
  • Discussion includes the importance of CPU speed, RAM, cache, and Front Side Bus (FSB) speed in determining overall performance.
  • There is mention of the "C:\WINDOWS\Prefetch" directory and its role in system performance, along with a suggestion to use defragmentation tools effectively.
Participants express a range of opinions on the best approach to address the performance issues, with no clear consensus on a single solution. Some advocate for hardware upgrades, while others emphasize software reinstallation or system maintenance.
The discussion highlights various factors that could influence CPU performance, including the operating system version and potential malware, but does not resolve the specific causes of the user's issues.
Gale
my computer is wicked freaking slow and it crashes a lot too. I've run virus scans and defragmented and i did a disk clean up. lately I'm getting pretty familiar with task manager cause I'm always closing programs i don't need because other programs are slow. I'm always having really high cpu usages. AIM, MSN messenger, Yahoo messenger, Firefox, Internet Explorer, and Music Match Jukebox tend to take the most, and the amount they use varies a ton. my computer struggles to run any two of those programs at once. Any one of them can use up to 80% cpu at a time, and then 10 minutes later only 20-30%. its a huge time pain and i don't know what i can do.
Computer science news on Phys.org
Has your computer always been this slow? You could look into a RAM upgrade.
Reinstalling Windows is sometimes the best solution.
its a laptop i just got last year. last spring i was having some problem where my computer screen would just go black, and i couldn't turn it back on, and i had to just hold the power key till it worked again. i sent it back to Dell and its been slow ever since. i have no idea what happened. I've never reformatted a computer or installed windows myself or anything. i wouldn't know how to go about it.
If it's only been slow since Dell sent it back, you might want to send it back again and make a case out of this. Reinstalling Windows isn't hard at all; just insert the XP CD and follow the wizard. It can take around 30-45 mins to reinstall but if you do it right you'll still have all your data. If you're interested, search Google for a step-by-step guide-- it's not as hard at all.
A lot will depend on CPU speed (1 GHz vs 3-4 GHz), RAM, cache, Front Side Bus (FSB) speed, and what other apps are running. Also, you might check for spy/add ware, some of which tries to access internet to send information about one's browsing habits. In this case, one should clean out Adware/Spyware cookies daily (better yet, block them in the first place), and perhaps search the registry file for insidious and evil apps.
Also, what is the OS XP? and if XP SP1 or SP2? If it was SP1, which has been upgraded to SP2, chances are the PC is hosed.
Reinstalling Windows seems extreme, especially if the registry file is rewritten to the configuration before the other apps were installed. I am just about at that point with a PC, but first I have to salvage some files.
Edit: Just learned about the " C:\WINDOWS\Prefetch " directory where some spyware programs may be lurking. They get activated at startup and can slow down a Windows machine.
Found this a techexams.net - http://www.techexams.net/forums/viewtopic.php?t=13052
The Prefetch directory serves a valuable purpose by analyzing files that you use at startup and when you run programs. Contrary to what some well-meaning but technically inaccurate articles suggest, this does not copy the files themselves. It creates an index to the location of those files on the hard disk, including the order in which they’re loaded. This allows Windows and Windows programs to start very quickly after the first time you use them.
The Prefetch directory has one additional salutary function when used in conjunction with the built-in defragmenting tool. Every three days, during idle times, this utility rearranges program code, moving it to the outside of the disk to make it more efficient when loading (to force Windows to perform this optimization without having to do a full defragmentation, use the Defrag.exe command with the -b switch. For instance: defrag c: -b).
  • · Replies 30 ·
39K
12K
