2nd order homogenous differential equation
The discussion revolves around solving a second-order homogeneous differential equation of the form y'' - 3y' + 2y = 0. The original poster expresses uncertainty after deriving the characteristic equation and finding the roots.
  • The original poster attempts to solve the differential equation by proposing a solution of the form y = e^rx and successfully derives the characteristic equation. They seek guidance on how to proceed after finding the roots.
Some participants provide insights into the general solution of the differential equation, suggesting that a linear combination of the solutions based on the roots is appropriate. There is acknowledgment that constants A and B cannot be determined without additional conditions.
The original poster mentions a lack of resources, such as textbooks and notes, which may affect their understanding of the topic. There is also a note about the inability to use LaTeX for formatting mathematical expressions.
zanazzi78
Solve the following for y(x);
y'' - 3y' + 2y = 0
I kind of know what to do up to a point but after that I`m stuck (bad notes and no textbook!).
Here`s what i`ve done so far, if someone could hint as how to finish this question i should be able to do the other 9 I have.
let y = e^rx then y' = r e^rx and y''= r^2 e^rx
therefor
r^2 e^rx -3re^rx + 2e^rx = 0
or
r^2 -3r +2 = 0
or
(r-2)(r-1)=0
i.e. r=2 and r=1
now i`m stuck! What do i need to do to find the solution?
(sorry about the lack of latex but my pc refuses to display it! so if you could not use it i would be gratefull)
Well, as you said you proposed solutions of the form [itex]y = e^{rx}[/itex] and you found r to be 2 and 1. A lineair combination of these solutions, together with two constants, is your complete solution to the homogenous equation.
So i would have a solution something like
y= A e^2x + B e^x
How do I find A and B or is that an irrelavent question?
y= A e^2x + B e^x
Your solution is fine and you cannot determine A and B, unless there are initial or boundary conditions. For a general n-th order DE, you'll have n constants.
TD thank you very much, your help is gratefully received.
You're welcome :smile:
  • · Replies 18 ·
  • · Replies 33 ·
