Is there an opposite law to the law of greed in physics?
  • Context: High School
  • Thread starter Thread starter deda
    Law
The discussion explores the concept of a "law of greed" in human behavior and its potential parallels in physics, particularly in relation to thermodynamics and stability. Participants examine whether there exists a physical law that could be considered an opposite to the law of greed.
  • One participant proposes that the law of greed, which suggests that those who have more tend to acquire even more, might have a counterpart in physics, specifically referencing the second principle of thermodynamics.
  • Another participant argues that heat moves from areas of higher temperature to lower temperature, suggesting that the concept of gaining more could be seen as opposite to the physical behavior of heat transfer.
  • A different viewpoint introduces the idea of instability, suggesting that systems become increasingly unstable until they collapse, which could reflect a similar dynamic to the law of greed.
  • Further elaboration on instability includes the analogy of a spinning top, which becomes more unstable until it falls, drawing a parallel to the accumulation of energy and chaos in a greedy system.
Participants express differing views on the relationship between the law of greed and physical laws, with no consensus reached on whether a direct equivalent exists in physics.
Some assumptions about the nature of greed and its parallels in physics remain unexamined, and the discussion includes various interpretations of stability and energy distribution without resolving these complexities.
deda
I'm sure that you're all familiar with the law of greed cause it's a part of the humman nature but I'll say it any way:
"The one that has more tends to have even more and he usually gets it". I wonder if there is an equivalent law to the law of greed in the domains of physics or if it applies in the same form? I'm sure that there is an oposite equivalent law and it's the 2nd principle of termodynamics, according to which:
"The object that has less heat cannot spontaneously give it away to an object with more heat"
Heat spontaneously moves toward less heat; therefore, that which has more will have less. Which would be the opposite of what you stated.
Nautica
Perhaps it could have something to do with an unstable state? It gets more unstable and more unstable until it finaly collapses, the engergy being distributed in several parts that our produced from the collapse?
you lost me
nautica
I was only observing that an unstable thing (atom, particle, etc) behaves in sort of that way (The one that has more tends to have even more and he usually gets it). It becomes more and more unstable, its energy being released more and more chaoticly and powerfully, until eventually it collapses.
A spinning top for instance- its wobbles continue to get bigger and more common, bigger and more common, bigger and more common, until finally it reaches the point where it can no longer function and it falls. This is similar to someone with a lot of things (energy) getting more and more (the chaotic realization of the energy).
  • · Replies 40 ·
  • · Replies 17 ·
