Physics of Golf: Angular Momentum & External Torque
  • Thread starter Thread starter sauri
    Golf Physics
The discussion centers on the angular momentum of a golf ball in motion, specifically when it rolls past a hole at a constant velocity. The angular momentum, defined as \(\vec{L} = \vec{r} \times \vec{p}\), is considered constant in magnitude but changes direction due to external torque. The participants emphasize the importance of analyzing forces in both X and Y directions to fully understand the dynamics involved.
  • Understanding of angular momentum and its mathematical representation
  • Familiarity with the concepts of torque and force equilibrium
  • Basic knowledge of vector mathematics and cross products
  • Experience with physics principles related to motion and velocity
  • Study the effects of external torque on angular momentum in various physical systems
  • Explore the relationship between linear velocity and angular momentum in rotational dynamics
  • Learn about the conservation of angular momentum in isolated systems
  • Investigate the application of vector calculus in analyzing motion in two dimensions
Physics students, educators, and anyone interested in the mechanics of motion, particularly in sports dynamics and angular momentum analysis.
sauri
A golf ball is putted too fast and rolls past the hole in a straight line, coming at closest approach to a distance d from the hole. Ignore friction and assume that golf ball moves at constant velocity.
What is the angular momentum of the golf ball about the hole?
Is the angular momentum constant about this point?
I believe that the angular momentum is constant but its direction changes due to an external torque. Yet the equation to use is beyond me could it be d(theta)=dL/L?
Actually... When we say a golf ball has a constant velocity, all the forces must add up to be zero.
Start with that by drawing components then doing a sum in the X and Y directions.
Consider the definition of the angular momentum of a particle:
[tex]\vec{L} = \vec{r} \times \vec{p}[/tex]
  • · Replies 35 ·
  • · Replies 17 ·
  • · Replies 30 ·
