The curvature cause by gravity implies absolute space?
The discussion revolves around the implications of gravity as a property of the geometry of spacetime, particularly whether this suggests that space is an independent entity, akin to Newton's concept of absolute space. Participants explore the relationship between gravity, curvature of space, and the notion of ether in the context of general relativity.
  • Some participants propose that if gravity is a geometric property of spacetime, it implies that space is an entity in itself, contrary to the views of Leibniz and Mach.
  • Others argue that general relativity introduces a "new aether" that does not imply absolute space, suggesting a distinction from classical ether concepts.
  • A participant highlights Einstein's 1920 speech, suggesting it reflects a change in attitude towards ether, indicating spacetime has physical qualities.
  • Some participants credit Minkowski with significant contributions to the merging of space and time, noting that his work laid the groundwork for understanding spacetime geometry.
  • One participant presents a model of spacetime as a compressible fluid, suggesting that matter's density affects its interaction with the vacuum, raising questions about the nature of space and its properties.
  • Another participant cautions against equating spacetime with a fluid, as this could imply an absolute reference frame.
  • There is a discussion about whether space can exist independently of matter, questioning the physical qualities of spacetime and its potential mass.
  • A participant questions if a magnetic field has mass, leading to further inquiry about the nature of spacetime as a field.
Participants express multiple competing views regarding the nature of space, gravity, and ether, with no consensus reached on whether spacetime can be considered an independent entity or if it implies absolute space.
Participants reference historical figures and concepts, indicating a reliance on various interpretations of general relativity and ether, which may not be universally accepted or clearly defined within the discussion.
MathematicalPhysicist
if gravity is a property of geometry of spacetime then does it imply that space is an entity in itself as Newton hypothesized, i mean if space is curved by a mass of a body and therefore creativg gravity around a particular radius then doesn't it imply that space isn't relative to masses as the relativists (as leibnitz and mach depicted) thought and it's also a key figure in nature (as an entity in itself).
Yes.
http://www.tu-harburg.de/rzt/rzt/it/Ether.html"
Not to put words in AE's mouth... but...
from http://www.tu-harburg.de/rzt/rzt/it/Ether.html (Einstein 1920)
I'd prefer it if his last paragraph was written (suggested edits in red)
"Recapitulating, we may say that according to the general theory of relativity spacetime is endowed with physical qualities; in this sense, therefore, there exists an ether. According to the general theory of relativity spacetime without ether is unthinkable; for in such spacetime there not only would be no propagation of light, but also no possibility of existence for standards of space and time (measuring-rods and clocks), nor therefore any space-time intervals in the physical sense. But this ether may not be thought of as endowed with the quality characteristic of ponderable inedia, as consisting of parts which may be tracked through time. The idea of motion may not be applied to it."
I think it's fair to say that, by 1920, these subtleties might not have been completely ironed out.
My $0.02.
Agreed. I mean, it was he who showed that space and time merge.
They way people generally say it around here is that GR provides for a "new aether", which is different from the classical lumiferous ether and does not "imply absolute space".
In my opinion, I think Minkowski deserves a signficant part of the credit for this "merging" of space and time. Certainly, Einstein (and others) set up the stage... but it was Minkowski (probably influenced by Felix Klein) that nailed down the geometrical structure of spacetime [which even Einstein didn't fully appreciate (or apparently like) until he was in the middle of formulating General Relativity].
Yep, those "mere shadows". Not exactly Einstein´s way of calling things.
Einstein's 1920 speech is more than the last paragraph - it reflects a change in attitude - Einstein's ether of 1920 has many of the characteristics we would associate with a substantive medium, except that of motion. Minkowski's space-time follows directly from the invariance of the interval - he presented a graphical description, but no new physics.
I agree with what you say about Einstein.
Likewise...
Minkowski's 1908 speech is more than a graphical description - it reflects a change in attitude - Minkowski's spacetime of 1908 has many of the characteristics we would associate with a 4-dimensional spacetime manifold, without its dynamics [via the Einstein field equations]. The point of Minkowski work is more than a "graphical description" (akin to a mere plot of some functions)... it's the emphasis on geometrical structures on a new object: the four-dimensional spacetime continuum [i.e. a particular 4-manifold with a noneuclidean metric]. Indeed, a coordinate system and functional relationships within that coordinate system can only take one so far. [pun intended]
Certainly, if all one were doing is Special Relativity, Minkowski's work could be regarded as a merely dotting an i. But on the road to General Relativity, one needs more than non-cartesian coordinate systems... one needs the geometrical structure of a more general 4-manifold.
So, I could agree that Minkowski provides no new physics... but Minkowski certainly provides a new geometrical (and historically important and fruitful) way to think about physics.
Some interesting reading
http://www-history.mcs.st-andrews.ac.uk/Biographies/Minkowski.html
http://www.univ-nancy2.fr/DepPhilo/walter/papers/einstd7.pdf
Loop quantum gravity,
Think of space-time (the vacuum) as a compressible fluid that surrounds and permeates all solid matter.
Think of all solid matter as porous to the vacuum to a degree determined by density.
Example; A steel ball is solid to us but at the atomic level there is a great deal of 'space' between the atoms and also between the electrons and nuclei of the atoms. This 'space' in between the particles is filled by the vacuum just as the 'space' between the sun and Earth is also filled with the vacuum. Therefore a steel ball is porous to the vacuum.
A lead ball is less porous than steel because the same volume of lead contains more particles per volume and therefore the compression of the vacuum within lead is greater that in steel.
The refraction of light as it passes from a solid to a gas is due to the condition of the vacuum within the solid being different to that of the gas. The density of the matter determines the condition of the vacuum within any substance, even the sun Earth system.
To understand this fully have a look at the flat-sheet solid ball analogy of how matter distorts space-time and correct it - yes that's right, correct it and express the distortion mathematically (there's a challenge for you)
Be careful relating space-time to a fluid - it implies an absolute reference frame (the reference frame of the fluid).
robphy - yes - I would agree that Minkowski's work is highly significant as a precursor to GR. Einstein depreciated it initially -then came to embrace it.
Since most of this discussion is going into the direction of a discussion about the existence of an "aether", a new one that must not be compared with the old one ... I would suggest to re consider the basis discussion of the general relativity for which one could (at the limit) consider that a coordinates system can be attached to any event. In this sense the set of all events (the differernt histories) is associated to a set of coordinates systems that is the "new aether"... but no more poetry in this representation: only mathematics...
but if space itself is curved, then it's curved with respect to some object.
if space were empty would the hypothesized aether still exist?
i feel that this new/old term is another name for absolute spacetime.
when i mean absolute, i mean that it has a "life" of its own, i.e if there weren't any matter in the cosmos then it would still exist.
and that is quite perplexing if this assumption is true cause then by the big bang theory matter and space started together, and if also space-time is an entity then what are its physical qualities, does it have mass?! or something like that, i mean usually in our life we see matter bend or curved.
but now also space time which is our reference frame, can change properties according to bodies in it.
obviously not, but is spacetime a field?
Depends on what you mean by a field. It's not too uncommon to regard the metric tensor as a field, in the sense that it's a tensor field and extremizes an action via a Lagrangian.
russ_watters said:
Does a magnetic field have mass?
Why not - it has energy - and the energy is proportinal to the square of the velocity of the electric charge - so the field can be analogized as the kinetic energy of an effective mass
well, my definition of a field, to which i think also russ meant, was the classical meaning i.e, the force acted on a mass or a charge.
such as the definitons of electric field E=F/q and gravity field.
i haven't yet learned of tensors and their applications but i reackon this semester i'll know more about them.
We can measure the electric force on a charge by comparing the motion of a charged particle to a reference, uncharged particle.
Unfortunately, there is no way to similarly measure the gravitational force on a particle without a reference "gravitationally uncharged" particle, which doesn't exist as far as we know.
There's a section on MTW on this, I don't recall the exact chapter, but it's probably not worthwhile to dig it up unless you have the textbook in question ("Gravitation" by Misner, Thorne, Wheeler).
  • · Replies 37 ·
  • · Replies 18 ·
  • · Replies 41 ·
