Thread Closed
reduction of quadratic form (principal axis)
Share Thread Thread Tools
Mar18-06, 02:51 PM   #1
i keep getting nonzero off diagonal elements when i try to reduce to simple sum of squares, of the equation
[tex]2 x_{1}^{2}+2x_{2}^{2}+x_{3}^{2}+2x_{1}x_{3}+2x_{2}x_{3} [/tex]
what i have is
[tex] \left(\begin{array}{ccc} x_{1} & x_{2} & x_{3} \end{array}\right)
2 & 1 & 0 \cr
1 & 2 & 1 \cr
0 & 1 & 1
\end{array} \right)
\left(\begin{array}{c} x_{1} \cr x_{2} \cr x_{3} \end{array} \right)
[/tex]
so my thought was to calculate the eigenvalues of the coefficient matrix above, which yield complex solutions from the characteristic equation
[tex] 1-6 \lambda+5 \lambda^{2}-\lambda^{3}=0 [/tex]
From the complex eigenvalues I obtain complex eigenvectors, which i'll post if necessary, but are rather lengthy. From the eigenvectors I choose to use Gram-Schmidt orthogonalization to form an orthonormal basis set. From which I construct a matrix with the corresponding basis set, and use diagonalize the system I have the diagonalization matrix
[tex] D = \left(\mid n \rangle \langle m \mid \right)^{T} A \left( \mid n \rangle \langle m \mid \right) [/tex]
where the matrix
[tex] \left(\mid n \rangle \langle m \mid \right) [/tex]
is the orthonormal eigenvector matrix. When I'm done with all of this I'm not getting a diagonalized matrix. I was wondering if I am making a mistake in my approach, or if anyone else does get a diagonalized matrix equation.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar18-06, 03:09 PM   #2
Recognitions:
The equation 1-6x+5x^2-x^3=0 has all real solutions. You could have known this because your matrix is symmetric and symmetric matrices in the reals are orthogonally diagonalizable in the reals.
Mar18-06, 03:25 PM   #3
Quote by 0rthodontist
That's interesting, I was bad and usinig Maxima to calculate the roots of the equation and getting imaginary components, interesting, when I plot and find the roots, you're correct the roots are all real. Thanks, for the tip, I didn't know that about symmetric matrices, either. Thanks again.
Mar18-06, 07:48 PM   #4
Recognitions:
Quote by xman
I was using my TI-89.
Mar19-06, 12:14 AM   #5
Perhaps the -89 is superior to my cas, even mathematica, maple given imaginary components, though on order of [tex]10^{-16}[/tex] or so. I wonder why that is. Not to mention I'm glad I'm not the only one whose cheats on algebra parts of problems...well that may get you into trouble as I found out today. Hey thanks again.
Thread Closed
Thread Tools
Similar Threads for: reduction of quadratic form (principal axis)
Thread Forum Replies
alternate form of the quadratic formula General Math 20
simplify to quadratic form General Math 6
Quadratic in standard form help....please Precalculus Mathematics Homework 5
Quadratic Form Calculus & Beyond Homework 3
How is the distance to the x-axis related to the roots of quadratic equations? General Math 4
