Redshift > 1.46 means Recessional Velocity over C?
  • Context: Graduate
  • Thread starter Thread starter Chaos' lil bro Order
    Means Redshift Velocity
The discussion centers around the implications of redshift values greater than 1.46 in relation to recessional velocity and the speed of light, exploring the calculations and interpretations within cosmology. Participants examine the differences between special relativity and general relativity in the context of cosmological redshift and recessional velocities.
  • One participant expresses confusion about calculating recessional velocity from redshift, suggesting a misunderstanding of the relationship as redshift approaches infinity.
  • Another participant points out that using special relativity to address cosmological problems is inappropriate, referencing past discussions on the topic.
  • A paper is recommended that discusses common misconceptions about cosmological horizons and superluminal expansion, emphasizing that recession velocities can exceed the speed of light without violating special relativity.
  • A participant seeks clarification on how to correctly calculate recessional velocity from redshift in cosmology, acknowledging their earlier mistake.
  • Reference to an equation in the linked paper is made, which purportedly provides the correct relationship between recessional velocity and redshift according to general relativity.
  • Another participant mentions a cosmological distance calculator that can compute comoving radial distance from redshift and relates it to recessional velocity, noting the model dependency of these calculations.
  • Several participants express appreciation for the references provided, highlighting their usefulness in understanding superluminal recession velocities and cosmological concepts.
  • A participant discusses the differences between standard special relativity definitions of distance and velocity versus those used in cosmology, emphasizing the complexity introduced by curved spacetime.
Participants do not reach a consensus; multiple competing views and interpretations regarding the relationship between redshift and recessional velocity remain evident throughout the discussion.
Participants note that the definitions of distance and velocity in cosmology differ from those in special relativity, which may lead to confusion. The discussion highlights the limitations of applying special relativistic concepts to cosmological scenarios.
I read this recently, but did not understand how one calculates this, since I'm used to:
Distance = Recessional Velociy / Hubble's Constant
= Beta x C / Hubble's Constant
ALSO SEE ATTACHMENT
I thought that as Z approaches infinity, Recessional Velociy approaches C. But clearly this cannot be true if a Red Shift of z =1.47 implies superluminal recessional velocity. Where are I going wrong?
Thanks much.
Astronomy news on Phys.org
And here is a paper you really need to read:
http://arxiv.org/abs/astro-ph/0310808"
Expanding Confusion: common misconceptions of cosmological horizons and the superluminal expansion of the Universe
Authors: Tamara M. Davis, Charles H. Lineweaver
Comments: To appear in Publications of the Astronomical Society of Australia, 26 pages (preprint format), 6 figures. Version 2: Section 4.1 revised
We use standard general relativity to illustrate and clarify several common misconceptions about the expansion of the Universe. To show the abundance of these misconceptions we cite numerous misleading, or easily misinterpreted, statements in the literature. In the context of the new standard Lambda-CDM cosmology we point out confusions regarding the particle horizon, the event horizon, the ``observable universe'' and the Hubble sphere (distance at which recession velocity = c). We show that we can observe galaxies that have, and always have had, recession velocities greater than the speed of light. We explain why this does not violate special relativity and we link these concepts to observational tests. Attempts to restrict recession velocities to less than the speed of light require a special relativistic interpretation of cosmological redshifts. We analyze apparent magnitudes of supernovae and observationally rule out the special relativistic Doppler interpretation of cosmological redshifts at a confidence level of 23 sigma.
Ok, I see my problem, how then does one calculate recessional velocity from redshift in Cosmology without making the SR mistake I made?
If you look at equation 1. in the reference I linked, it gives the appropriate relation between recessional velocity and redshift for general relativity.
I think I mentioned Ned Wright cosmology tutorial in another page on another forum, but it appears I edited out the references to his cosmological distance calculator.
This will calculate comoving radial distance from the redshift (z), and Hubble's law will give the recessional velocity from the comoving distance (this is mentioned on the calculator output).
The javascript calculator itself is at
http://www.astro.ucla.edu/~wright/CosmoCalc.html
the background information on it is contained in
http://www.astro.ucla.edu/~wright/cosmo_02.htm, including a link to the derivation (which won't be intelligible without knowledge of GR).
The conversion from redshifts to distances (and recessional velocities) is highly model dependent, though. Ned Wright's calculator defaults to H0 = 71 (he doesne't give units, presumably this is in (km/sec)/Mpc, [itex]\Omega_m = .27[/itex], and [itex]\Omega_v = .73[/itex], which I believe are the Lambda-CDM values.
Thanks Pervect, great post, clear as day.
Excellent reference, matt.o. That is my personal favorite for explaining superluminal recession velocities. Ned Wright also gives a very good explanation for this, as well as numerous other issues in cosmology. His FAQ is a great read, IMO, for anyone wishing to learn the fundamentals.
Here's my favorite example:
The text in
associated with the attached image evaluates a special case where both the standard SR distances and velocities and the cosmoloigcal distances (comoving distance) and velocities (Hubble velocity) are defined.
More advanced readers might recognize this as the "Milne" cosmology, other less advanced readers may not recognize it from this description - Ned Wright doesn't use this particular phrase in his text.
The point of this image though is to point out that the cosmologists are measuring something that's different from the standard SR notion of distance and velocity. This can be seen by this specific example, which applies to a cosmology where both concepts exist.
The SR notions of distance and velocity cannot, unfortunately, be generalized to situations where the Riemann tensor is non-zero (i.e. the spacetime is curved). SR notions of distance and velocity require a Minkowskian metric. The example was specifically chosen so that the space-time in question has both a Minkowskian metric (a static flat space-time description) and a Milne metric (a non-static expanding space-time description) which are mathematically totally equivalent, representing the same physical spacetime (a spacetime with a very low matter density).
The cosmological defintions of distance and velocity are more general than the SR defintions, but they do NOT reduce to the SR defintions of distance and velocity in this limit of low matter density.
As I went on at some length in another thread, the important point here is "many distances, many velocities". One should be aware that the definitions of distance (of which there are many) used by cosmologists are not the same as those used in SR, and that this remark also applies to velocities (though in this case only the Hubble recessional velocity is widely used AFAIK).
This should not be terribly surprising to someone who is familiar with SR - one of the reasons for this difference in defintions is the usual problems of defining "simultaneous" events, which is a necessary prerequisite to be able to measure distance.
  • · Replies 17 ·
14K
  • · Replies 16 ·
17K
  • · Replies 23 ·
