What is the role of wavefront in high explosives?
The discussion centers on the distinction between detonation and combustion in high explosives, emphasizing that detonation occurs at supersonic speeds, while combustion occurs at subsonic speeds. It highlights the engineering challenges in internal combustion engines, particularly regarding the prevention of detonation to avoid damage to piston heads. The conversation references the role of shockwaves in these processes, noting that deflagration, even in rapid flame scenarios, operates at tens of meters per second, contrasting with the supersonic shockwave characteristic of detonation.
  • Understanding of detonation and combustion principles
  • Familiarity with internal combustion engine mechanics
  • Knowledge of shockwave behavior in explosive reactions
  • Basic concepts of Pulse Detonation Engines
  • Research the mechanics of detonation in high explosives
  • Explore the engineering challenges of Pulse Detonation Engines
  • Learn about shockwave propagation in different media
  • Investigate the effects of fuel/O2/pressure combinations on combustion
Engineers, physicists, and researchers interested in explosive materials, combustion processes, and the design of advanced propulsion systems.
Nim
How slow can an explosion possibly be?
I think the generally accepted difference between "detonation" and "combustion" is wether the reaction takes place at supersonic speed for the medium being burned.
In an internal combustion engine, for example, care is taken to avoid a feul/O2/pressure combination that will "detonate" the fuel in the cylinder, because such an explosion will damage the piston heads (this is one of the main engineering obsticals to Pulse Detonation Engines). Although I've never seen it explicitly stated, the difference between detonation and combustion is always discussed in terms of a supersonic or a subsonic shockwave.
For example, http://www.popsci.com/popsci/aviation/article/0,12543,473272-2,00.html no pulse detonation states that...
In deflagration—even in "fast flame" situations ordinarily called explosions—that reaction moves at tens of meters per second at most. But in detonation, a supersonic shock wave slams down the tube...
Not a clear-cut definition, as most people would refer to what goes on inside an engine cylinder as an "explosion".
  • · Replies 17 ·
11K
  • · Replies 29 ·
  • · Replies 38 ·
