Questions About High-Tc Superconductivity - Natski
  • Context: Graduate
  • Thread starter Thread starter natski
    Confusion
The discussion revolves around high-temperature superconductivity (high-Tc superconductivity), focusing on definitions and properties such as the pseudo-gap, Knight shift, grain boundaries, and spectral frequency lines. Participants explore theoretical concepts and seek clarification on various terms and phenomena related to superconductors.
  • Natski inquires about the definition of the pseudo-gap, noting its existence above the critical temperature (Tc) in high-Tc superconductors and contrasting it with conventional superconductors where a gap forms below Tc.
  • Some participants discuss the Knight shift, with one noting it as an NMR-related question and asking about the inquirer's knowledge of NMR.
  • There is a question regarding the definition of a grain boundary, with a participant clarifying that it refers to the boundary between single-crystal domains.
  • Another participant questions whether spectral frequency lines change when a superconductor transitions from room temperature to a superconducting state, suggesting that Cooper-paired electrons might affect the band gap.
  • There is a request for data on spectral frequency differences between superconducting and non-superconducting states.
  • Clarifications are sought regarding the term "spectral frequency lines," with references to absorption spectra and their changes in the Cooper-paired state compared to the non-Cooper paired state.
  • A participant explains that absorption spectra are rarely studied in superconductors due to the nature of metals and the penetration of electromagnetic radiation, emphasizing the use of reflected light in optical conductivity experiments.
Participants express various questions and hypotheses, but there is no consensus on the definitions or implications of the discussed concepts. Multiple viewpoints and uncertainties remain regarding the effects of temperature on spectral frequencies and the nature of absorption spectra in superconductors.
Some definitions and assumptions about terms like "pseudo-gap," "Knight shift," and "grain boundary" may depend on specific contexts or interpretations within the field of superconductivity. The discussion does not resolve these nuances.
natski
Hi,
I've been reading a book recently about high-Tc superconductivity and I have some questions. They are really just questions about the definitions of various properties and variables...
1) Definition of the pseudo-gap? (and for that matter the 'gap' too)
2) The Knight shift?
3) What exactly is a 'grain boundary'? Does this mean the whole bulk material is granular or just NS boundaries?
Thanks,
Natski
natski said:
Hi,
The pseudogap, as applied to HTS, is a gap in the single-particle energy spectrum that exists above Tc.
In conventional superconductor, a gap forms below Tc in the energy spectrum. This gap corresponds to the strength of the coupling between 2 electrons that make up the Cooper pair. So to break up one, you need to supply that much energy. Above Tc when the material isn't in the superconducting state, no gap.
In HTS, while there appears to be no gap in the overdopped regime, there clearly is a gap (often nothing more than a depression in the single-particle spectrum) above Tc for the optimally doped and underdoped cuprates. This is what has been called the pseudogap.
This is an NMR question and not specifically on HTS. How much of NMR do you know?
This is a materials question and also not specific to HTS. Grain boundary simply is the boundary between one single-crystal domain with another.
Zz.
Does the Spectral Frequency lines change in a Superconductor when going from room temperature to Super Cooled?
I would assume that the cooper paired Electrons would change the band gap and cause a shift in the Spectral Frequency lines, wouldn't it?
If so, is there any data that displays the differences in Spectral Frequencies between temperature dependancy states in a Superconductor compared to its non-Superconductive state? :bugeye:
What are "spectral frequency lines"?
Zz.
Zz.
Hi Zz.
Please forgive my lack of information when delivering my last question.
http://csep10.phys.utk.edu/astr162/lect/light/absorption.html"
I was wanting to know if the absorption spectra changed in a Superconductor when going into a Cooper Paired State compared to its non Cooper Paired State.
_____________________________________
Sincerely sits to down to listen to the Illuminated one.:bugeye:
Intuitive said:
Hi Zz.
You do know that "lines" are discrete absorption spectrum, where as "bands" are continuous. The "gap" that is in the single-particle spectrum is the absence of states in the ENERGY BAND.
Secondly, you very seldom (I can't find any) see studies of "absorption" spectrum for a superconductor. Why? Because it's a metal (even a bad one), and within the relevant range, an EM radiation can only penetrate up to the skin depth of the material, which is even significantly less in the superconducting state. So this isn't a "prism" where light can be diffracted and looked at after it comes out of the medium. Practically all of optical conductivity experiments on HTS are done by looking at the reflected light and then reconstructing the transmitted portion via Kramers-Kronig transformation. You do not see any spectral "lines" here. You do however detect a range where there is a dip in the spectral response that corresponds to the energy gap.
Zz.
Thanks for answering my question Zz.
Your the Greatest.
Jerry:bugeye:
  • · Replies 21 ·
