Inverse of a linear transformation
The inverse of the linear transformation T represented by the matrix \(\begin{pmatrix} a & b \\ c & d \end{pmatrix}\) can be derived by recognizing that the transformation maps a 2x2 matrix into another 2x2 matrix, necessitating the use of a 4x4 transformation matrix. The transformation results in four equations: \(p = a + 2c\), \(q = b + 2d\), \(r = 3c - a\), and \(s = 3d - b\). To find the inverse, one must solve these equations for \(a\), \(b\), \(c\), and \(d\) in terms of \(p\), \(q\), \(r\), and \(s\).
  • Understanding of linear transformations
  • Familiarity with matrix representation
  • Knowledge of solving systems of equations
  • Basic proficiency in manipulating 4x4 matrices
  • Study the properties of linear transformations in depth
  • Learn how to derive inverses of 4x4 matrices
  • Explore the application of row reduction techniques for matrix equations
  • Investigate the relationship between 2x2 and 4x4 matrix transformations
Mathematicians, students of linear algebra, and anyone involved in advanced matrix operations will benefit from this discussion.
stunner5000pt
find the inverse of [tex]T \left[ \begin{array}{cc} a&b \\ c&d \end{array} \right] = \left[ \begin{array}{cc} a+2c&b+2d \\ 3c-a&3d-b \end{array} \right][/tex]
do i row reduce the transformation matrix... it doesn work , though
is there an easier way??
You have to recognize that writing a b c d as a matrix like that is similar to writing a b c d as a column vector. The _real_ matrix of the transformation is 4x4.
As Orthodontists pointed out (remarkable how good at math a dentist is!) since this maps a 2 by 2 matrix into a 2 by 2 matrix, the actual "transformation matrix" is 4 by 4. If you don't want to write all of that out, try a more basic approach. Using p,q,r,s as the components of the result of the transformation, you have four equations:
p= a+ 2c, q= b+ 2d, r= 3c- a, s= 3d- b, four equation in the four "unknowns" a, b, c, d. Solve for a, b, c, d in terms of p,q,r,s. that will give the equations for the inverse transformation.
10K
