Thread Closed
Find a cubic function...
Share Thread Thread Tools
Mar26-06, 11:08 AM   #1
Find a cubic function [tex] f(x) = ax^3 - bx^2 + cx - d [/tex] that has a local maximum value of 40 at x = 1 and a local minimum valud of -68 at x = 4
Since x = 1 and x = 4 are the max and min, respectively, then f'(x) must equal 0 at x = 1 and x = 4. Therefore [tex] f'(x) = (x-1)(x-4) = x^2 - 5x +4 [/tex]
Using the original function [tex] f'(x) = 3ax^2 - 2bx +c = x^2 - 5x + 4[/tex]
Setting the terms equal to each other we get
[tex] 3ax^2 = x^2 \Rightarrow a = \frac{1}{3} [/tex]
[tex] -2bx = -5x \Rightarrow b = \frac{5}{2} [/tex]
[tex] c = 4 [/tex]
Substituting these values back into the original equation I get
[tex] f(x) = \frac{x^3}{3} - \frac{5x^2}{2} + 4 - d [/tex]
When I solve for d using x = 1 and f(x) = 40 I get
[tex] d = \frac{1}{3} - \frac{5}{2} - 36 = \frac{-229}{6} [/tex]
However, when I solve for d using x = 4 and f(x) = -68 I get
[tex] d = \frac{4^3}{3} - \frac{5(4^2)}{2} + 84 = \frac{226}{3} [/tex]
Any ideas where I went wrong, or if I was down the wrong track to start with?
Thanks
Jeff
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Mar26-06, 11:22 AM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Eeh, from what I can see, we must have:
[tex]f'(x)=K(x-1)(x-4)[/tex], where K is some arbitrary constant.
Mar26-06, 12:38 PM   #3
So if that was brought into the equation, would I be solving for a, b, c, & d in terms of K?
Mar26-06, 01:14 PM   #4
Recognitions:
No, you need to solve for a value of K and a value for the integration constant which give you the desired values at x=1 and 4. And don't worry about solving a,b,c,d seperately as unknown variables. Just find the right cubic and then you just can read them off.
Mar26-06, 01:21 PM   #5
Recognitions:
Well, there was nothing inherently wrong about Jeff's idea. A bit cumbersome, that's all.
Mar26-06, 04:43 PM   #6
Sorry, not familiar with the idea of an itegration constant. We just finished sections of optimization problems and Newton's method. The next section is antiderivatives. So I have to solve this without any concept of integration.
Mar27-06, 07:27 AM   #7
Could someone direct me towards information on finding the integration constant, if that is indeed the most direct way to solve this problem?
Thanks
Jeff
Mar27-06, 07:29 AM   #8
Recognitions:
Scratch the whole integration constant idea gig: no integration for you.
Mar27-06, 07:46 AM   #9
Recognitions:
Retired Staff Staff Emeritus
f'= k(x-1)(x- 4)= kx^2- 5kx+ 4k= 3ax^2+ bx+ c so
a= k/3, b= -5k and c= 4k. Evaluate f(x)= (k/3)x^3- 5kx^2+ 4kx+ d at 1 and 4 to get two equations for k and d.
Mar27-06, 07:51 AM   #10
Recognitions:
We have 4 unknowns, hence we need 4 equations to solve: they are f(1)=40, f(4)=-68, f'(1)=0, and f'(4)=0.
Mar27-06, 08:15 AM   #11
J77
Where you went wrong in finding d in your OP was substituting the values at f'(x)=0 into f(x)...
You may also want to use: f''(1)<0, f''(4)>0
Mar27-06, 09:32 AM   #12
Thanks to all. I used K(x-1)(x-4) = 0, solved for a, b, and c, then went back to the original equation and used x = 1 and x = 4 to get two equations for d in terms of K. I set them equal, solved for K, and when I plugged it back in I ended up with values for a, b, c, and d that satisfied all conditions.
May15-07, 06:24 PM   #13
Can anyone explain this further? I have a similar problem, and I'm having trouble following what the correct answer Jeff figured out in the end was.
How does one make an equation for d in terms of K, for instance?
Thread Closed
Thread Tools
Similar Threads for: Find a cubic function...
Thread Forum Replies
Cubic Function General Math 2
Getting Cubic Function Calculus & Beyond Homework 5
Finding cubic function Precalculus Mathematics Homework 3
Inverse of a Cubic Function General Math 12
Find The Equation Of A Cubic Relationship Given This Data Introductory Physics Homework 10
