Measuring Mass of the Cosmos: Charles Hellaby's New Paper
  • Context: Graduate
  • Thread starter Thread starter marcus
    Cosmos Mass
The discussion revolves around a new paper by Charles Hellaby that proposes a method for measuring the mass of the cosmos on gigaparsec scales. Participants explore the implications of Hellaby's approach, which involves the geometric role of the maximum in the areal radius and its connection to cosmic geometry and observations. The conversation includes theoretical considerations, potential applications, and challenges related to the proposed method.
  • Some participants express skepticism about Hellaby's paper, describing it as "weak" and questioning the validity of its claims.
  • One participant suggests a thought experiment involving four identical spiral galaxies at different redshifts to explore angular sizes, proposing that the galaxy at z = 2 appears smallest.
  • Another participant confirms that the angular size is indeed smallest at z ~ 2, while galaxies beyond this redshift appear larger, referencing Hellaby's idea of deriving information from the maximum redshift at which galaxies look largest.
  • Some participants challenge the notion of increasing angular size with redshift, expressing that it seems counterintuitive and potentially incorrect, despite acknowledging evidence that suggests this behavior.
  • References to external resources, such as cosmological calculators, are made to support claims about angular diameter distance and its relationship to redshift.
Participants generally do not reach consensus, with some expressing agreement on certain points while others contest the validity of the claims made in Hellaby's paper. The discussion remains unresolved regarding the implications of angular size behavior and the overall validity of the proposed method for measuring cosmic mass.
Participants note that assumptions about cosmological parameters and the nature of the universe may influence the discussion. There are also references to the limitations of current understanding and the complexity of the concepts being discussed.
marcus
Dearly Missed
In case anyone is interested, here is a new paper just out.
Any comment?
http://arxiv.org/abs/astro-ph/0603637
The Mass of the Cosmos
Charles Hellaby
6 pages, 9 graphs in 3 figures
"We point out that the mass of the cosmos on gigaparsec scales can be measured, owing to the unique geometric role of the maximum in the areal radius. Unlike all other points on the past null cone, this maximum has an associated mass, which can be calculated with very few assumptions about the cosmological model, providing a measurable characteristic of our cosmos. In combination with luminosities and source counts, it gives the bulk mass to light ratio. The maximum is particularly sensitive to the values of the bulk cosmological parameters. In addition, it provides a key reference point in attempts to connect cosmic geometry with observations. We recommend the determination of the distance and redshift of this maximum be explicitly included in the scientific goals of the next generation of reshift surveys. The maximum in the redshift space density provides a secondary large scale characteristic of the cosmos."
It would appear that the author has thought of another way to gauge the universe's mass----or the mass of a large chunk. We already have estimates, as he points out. But apparently here is a method that has not been tried.
Space news on Phys.org
I think it is wrong, marcus. I read that paper and found it . . . weak.
I see:smile:
Not a big deal. I would not urge the paper on anyone---just wondered if anyone might be interested.
the kind of question it suggests to me is this: suppose you have 4 identical spiral galaxies at different distances
1. is at z = 1
2. is at z = 2
3. is at z = 3
4. is at z = 4
the question is, which galaxy looks SMALLEST in the sense of having the smallest angular size?
and if you can say that, then also which galaxy looks largest: has the biggest angular size
assume some usual cosmological parameters like-----Hubble = 71
Omega_Lambda = 0.73, Omega_matter 0.27
and that your telescope is sensitive in the infrared and can "see" the objects well enough to tell their angular sizes
1. is at z = 1
2. is at z = 2
3. is at z = 3
4. is at z = 4
The angular size of object of size [itex]dl[/tex] located at angular distance [itex]D_A[/itex] is:<br /> <br /> [tex]d\theta = \frac{dl}{D_A}[/tex]<br /> <br /> Now, go for example to my <a href="http://www.geocities.com/alschairn/cc_e.htm" target="_blank" class="link link--external" rel="nofollow ugc noopener">cosmological calculator</a> and fill in the redshift:<br /> <br /> z = 1, D<sub>A</sub> = 5410.05 Mly<br /> z = 2, D<sub>A</sub> = 5701.73 Mly<br /> z = 3, D<sub>A</sub> = 5267.91 Mly<br /> z = 4, D<sub>A</sub> = 4764.96 Mly<br /> <br /> This means that [itex]d\theta[/tex] is smallest at z ~ 2. Objects beyond z ~ 2 start increasing in angular size.[/itex][/itex]
That is an interesting artifact, hellfire.
hellfire said:
The angular size ... is smallest at z ~ 2. Objects beyond z ~ 2 start increasing in angular size.
Right!
so to answer the question as stated, the galaxy at z = 2 looks smallest and the one at z=4 looks largest
Hellaby's idea is to process future astro data to extract an estimate of
z_max
the redshift at which galaxies look their largest.
He then proposes to derive some other information from that, like converting z_max to a distance and so forth.
IIRC Hellaby's papers go back to at least 1985. It is conceivable that he knows what he's talking about. Also possible that he doesn't----that it is not a good way to extract info about the universe from astro data.
Any other comment?
The increase of angular size with a z cutoff just smacks me as wrong. I agree the evidence suggests this possibility, but, our universe is weird enough without introducing that complication.
yes, in line with the droll irony of your sig.
yes, weird.
but then again maybe not so weird, maybe even intuitiveit's intuitive from what you get in the first two or three installments of ned wright's Cosmology Tutorial
remember the first time you looked at the tutorial and saw that
THE LIGHTCONES LOOK LIKE TEAR-DROPS?
when you look back you see a universe that was smaller, so an individual galaxy occupies a larger solid angle on the ball of what you see at that z
I am just trying to massage your intuition Chronos, not be rigorous, so don't argue back, just relax.
it is obvious from observations that this happens
there is a great way to get intuition about this fact of angular size increasing with distance after about z = 2
You can find it out for your self just by PLAYING WITH NED WRIGHT'S COSMO CALCULATOR!
http://www.astro.ucla.edu/~wright/CosmoCalc.html
that calculator is such a useful teaching tool!
it takes a z input
and one of the many things that it gives output is the kiloparsec diameter corresponding to ONE ARCSECOND
it outputs this in units of kpc/"
try it
you can find the exact z where the kpc/" is a max
and then check that as you increase z from there on, the kpc/" gradually slopes off
we live in a beautiful funhouse mirror vision better than any actual funhouse
  • · Replies 30 ·
  • · Replies 61 ·
  • · Replies 20 ·
  • · Replies 18 ·
