What Is the Ratio of y2/y1 in a Single Slit Experiment?
The ratio of y2/y1 in a single slit experiment can be calculated using the formula for the position of the first minimum, which is y = λ(D/a). For 440 nm light, the position is y1, and for 529 nm light, the position is y2. The ratio y2/y1 can be expressed as (λ2/λ1), where λ2 is 529 nm and λ1 is 440 nm, leading to a definitive ratio of 1.2.
  • Understanding of wave optics principles
  • Familiarity with the single slit diffraction pattern
  • Knowledge of the relationship between wavelength and diffraction
  • Basic algebra for ratio calculations
  • Study the derivation of the single slit diffraction formula
  • Learn about the effects of slit width on diffraction patterns
  • Explore the impact of wavelength on the position of minima in diffraction
  • Investigate experimental setups for measuring diffraction patterns
Physics students, educators, and researchers interested in wave optics and diffraction phenomena.
jh24628
i really don't know where to start with this problem
Consider the setup of a single slit experiment
The first minimum for 440 nm light is at y1.
The first minimum for 529 nm light is at y2.
what is the ratio of y2/y1?
i know that the distance between two max is
(wavelength*dis between the slit and the screen)/(dis slit separation)
Careful. For a single slit experiment, the position of the first minimum is given by:
[tex]y = \lambda \frac{D}{a}[/tex]
where D = distance to screen; a = width of the slit
  • · Replies 33 ·
  • · Replies 20 ·
  • · Replies 32 ·
