Would a Body at the Center of the Earth Have Weight?
  • Context: Undergrad
  • Thread starter Thread starter stevepark
    Body Center Earth
The discussion revolves around the question of whether a body at the center of the Earth would have weight. Participants explore the implications of gravitational forces and the effects of mass distribution within the Earth, touching on theoretical and conceptual aspects of gravity.
  • Some participants argue that a body at the center of the Earth would experience a very high weight due to gravitational forces, referencing Newton's law of gravitation.
  • Others counter that at the center, gravitational forces from surrounding mass would cancel out, resulting in near-zero weight.
  • One participant suggests that if the Earth were treated as a point mass, the weight would tend to infinity as the distance approaches zero, but this assumption is challenged by others.
  • Another viewpoint highlights that if a spherical cavity were created at the center of the Earth, the gravitational field would vanish throughout the cavity, including at the center.
  • There is mention of a formula for gravitational force inside a spherical mass, indicating that as the distance from the center approaches zero, the force also approaches zero.
  • Some participants express confusion over the implications of weight being both zero and infinite, reflecting the complexity of the discussion.
Participants do not reach a consensus; multiple competing views remain regarding the weight of a body at the center of the Earth and the interpretation of gravitational forces in that context.
Limitations include assumptions about mass distribution, the applicability of Newton's law at different distances, and the implications of treating the Earth as a point mass versus a distributed mass.
stevepark
A science mag article I read recently claimed that a body at the center of the Earth would have a very high weight. I don't see how a body at the center of the Earth would have any weight as any given mass has an equal opposite cancelling it out.
Explainations?
stevepark,
Compressed by cumulative matter, it would have a high density (mass/length3), but as you point out, a symmetric cancellation in gravity making a near-zero weight~(mgr)-(mgr).
gravity at center of large mass
Thanks for your response.
According to Newton's law F=GmM/r^2, a body of mass at a distance r from the center of the Earth (assumed that all mass of the Earth has been concentrated in the center) experiences a weight F. So, as r is very small near the center of the earth, the body will experience a very large weight force F.
No it won't. Where is the mass you are attracted by? All around you if you are at the Earth's centre. You can only assume the Earth acts as a point mass IF you are on or above the surface.
Read Loren's reply above.
I think Loren is quite right, but for a body at the center of the Earth r will tend to 0. According F=GmM/r^2 F will tend to infinity no matter what value M has. That's my opinion how the article should be interpreted, although Loren is also quite right.
So you are both right huh? Your weight will be both zero and infinite!
If you insist on thinking that the Earth's mass only acts like a point mass on you, DESPITE, you being in the centre of it, then your 'logic' works.
You are though wrong.
I agree with Adrian
Yeah, OK, I admit. That makes more sense.
grtavity
If the Earth were two halves, M1 & M2, gravity at the center distance betweent them, (C=1/2D), would be 0.
M1----------C----------M2
But:
If the two halves were together, with virtually no D,
M1CM2
then the pressure of M1<-->M2 at the center would be the max the two bodies could produce, would it not?
Explainations?
Weight is defined as the force required to support a body in a gravitational field so that it remains at rest. Suppose you hollowed out a spherical cavity centered at the center of the Earth. Then the gravitational field inside the cavity would not only vanish at the center but everywhere inside the cavity.
If the cavity is not centered at the center of the Earth then the field is uniform and the gravitational acceleration is proportional to the distance from the center of the Earth.
See - http://www.geocities.com/physics_world/gr/grav_cavity.htm
Arcon
This formula will only give the weight of an object for distances (from the Earth's center) greater than the radius of the earth.
The gravitational field inside a spherical body of mass M is
a linear function of the distance from the center,
[tex]F = \frac{GMmr}{R^3}[/tex]
where R is the radius of the sphere and r is the distance of the object (mass m) from the center. As r goes to 0, the force will vanish.
What's interesting about this is: if you had a tunnel dug through the Earth (from one side to the other), an object dropped in the hole would eventually come back out (since the force is like that of a spring, a restorative force), and so the object would exhibit simple harmonic motion.
  • · Replies 51 ·
  • · Replies 24 ·
  • · Replies 22 ·
11K
