Multiplying Rational Expressions
The discussion focuses on the multiplication of rational expressions, specifically the problem involving the expression (1+4x+4x^2)/x multiplied by 3x^4/(12x^2-3). The user initially simplifies incorrectly, resulting in an incorrect answer. A participant points out the need for careful factoring and suggests writing out all steps clearly. The correct factoring leads to the answer x^3(1+2x)/(2x-1), emphasizing the importance of thoroughness in mathematical processes. The conversation highlights common mistakes in factoring and simplification.
wScott
This is a question I have to do for tomorrow
\frac{1+4x+4x^2}{x}\times\frac{3x^4}{12x^2-3}.
I just factor the tops and then cancel where I can. This is what I came up with:
\frac{3x^4}{12x^3-3x}
But the answer key says:
\frac{x^3(1+2x)}{2x-1}
What have I done wrong?
You aren't factoring carefully enough. You've got leftover factors floating around. Write out ALL of the steps!
=\frac{(2x+1)(2x+1)}{x} \times \frac{3x^4}{3(2x-1)(2x+1)}
NOW do your cancelling.
-Dan
Ouch. That hurt my pride. I forget to factor the factor usually, that's going to kill me one day.
thanks for pointing out that pesky little mistake.
Happens to the best of us. No worries, mate! :biggrin:
-Dan
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
