Grinding Camshafts: Cost & Strength Benefits
  • Thread starter Thread starter sid_galt
    Strength
The discussion revolves around the reasons for grinding camshafts, exploring the cost and strength benefits compared to alternative manufacturing methods such as diecasting and welding cam lobes. Participants examine aspects such as dimensional control, surface finish, and the complexities involved in manufacturing camshafts, including the implications of 2D versus 3D profiles.
  • Some participants suggest that grinding is preferred for camshafts due to the need for precise dimensional control and superior surface finish.
  • Others argue that while cam lobes could theoretically be made in dies, achieving the necessary tolerances and surface finish would be challenging without secondary machining.
  • A participant notes that the wide variations in camshaft designs complicate the casting process, making grinding a more straightforward and less error-prone option.
  • There is a discussion about whether surface finish can be achieved post-casting, with some agreeing that final machining could involve grinding to meet required specifications.
  • Concerns are raised about the implications of cam profiles being 3D rather than 2D, particularly regarding wear patterns and the mechanics of pushrods in engines.
  • One participant calculates contact stresses in a hypothetical scenario involving cam and pushrod interaction, questioning the feasibility of manufacturing pushrods with point contact under high stress.
  • Another participant highlights the importance of surface hardness and finish in resisting fatigue due to high contact stresses, linking this to the costs associated with manufacturing bearings and gears.
Participants express multiple competing views regarding the manufacturing processes for camshafts, with no consensus reached on the superiority of grinding versus diecasting and welding. The discussion remains unresolved on several technical aspects, including the implications of 2D versus 3D cam profiles.
Limitations include assumptions about manufacturing tolerances, the complexity of camshaft designs, and the potential for variations in surface finish and hardness requirements. The discussion also touches on unresolved mathematical calculations related to contact stresses.
sid_galt
Why are camshafts normally grinded? Is diecasting and then welding camlobes to a shaft too expensive and/or does it give less strength?
First two reasons that come immediately to mind:
- Dimensional control
- Surface finish
Even if you die cast and fabricated a camshaft, and found some obscure way of ensuring that your ordinates were absolutely spot on (doubt you'd achieve this with any welding process), you'd have nowhere near the surface finish needed.
What do you mean by dimensional control? Forgetting other factors for a movement, can't cam lobes be made in dies since cams only have a 2d profile, not a 3d one.
FredGarvin said:
- Surface finish
Can't surface finish be done through grinding after the casting? That would save a lot of grinding.
I think just the wide variations in the design of camshafts (I mean more then just lobe ramp rates or separation angle but basic dimensions like length or spacing and even center circle diameter) would make the casting process very complicated with little gain to offset the increased workload. Even if you could ship it out to less expensive overseas labor, it seems more expensive and error prone than just grinding down round blanks that can be checked for runout before grinding (and melted and recast if out of spec) rather than trying to assemble 2 dozen pieces. I can't see grinding time being that expensive.
You mean that due to the wide possibilities using grinding (not to mention its uses elsewhere too), grinding comes out to be overall cheaper than dieing?
How does one calculate the cost of grinding and the time taken?
Having a 2D profile has nothing to do with it. When I say dimensional control, I mean in the sense that most rotating surfaces such as those found on cams running locations and bearing locations are held to very tight tolerances that are not achievable (easily) any other way. You definitely will not hold four decimal places (english) out of a die or casting. It must have secondary machining operations after the bulk deformation process. The thing about welding, ESPECIALLY on rotating hardware is that it is difficult to maintain runout on all of the surfaces. You would have to go through rounds of annealing after the weld along with straightening. It would add more work. We weld shaft sections sometimes, especially for one of a kind R&D hardware. However, there is a real art to getting it right plus getting the rotating group to balance in the end.
Yes. You are correct. I would assume that the final machining is a fine cut grind, akin to a very light lathe cut, to get the surface roughness required.
Actually I'm not sure if a cam on an engine camshaft really is a 2D profile. If you pull a valve cover and watch the pushrods while the engine is running you will notice that they spin. There is only one way I know of for this to happen and that for the cam lobe to be ground slightly larger on one side. Usually the lifter has a slight convex shape to the part that contacts the cam. Come to think of it I've noticed the wear pattern on a camshaft and it is usually off to one side.
I have seen industry articles saying that cam machining is getting to be very difficult because of the 3D aspect. I am not sure if the 2D has been done away with. I guess in the context of the original question it doesn't really matter.
Wait, if the cams are having a 3d profile, wouldn't that mean that the pushrod is at contact with the cam at only a point (assuming pushrods are used in the engine)?
Wouldn't that make the stress unacceptable?
EDIT: Just calculated, two spheres in point contact with radius 1 cm and force on valves = 560 N will have a contact stress of 260 MPa. Ofcourse the fact that one of the spheres is actually a rod and friction effects etc. would distort this figure, but my point is that point contact stresses with such high forces are EXTREMELY high not to mention the surface cyclic stresses caused by a spinning rod and a spinning camlobe. Wouldn't such pushrods which have point contact be expensive to manufacture and grind?
The Hertz stresses are higher than usual, which is why they rods and cams are usually surface hardened and then ground. This also gives you some insight into why things like bearings and gears can be very expensive. The hardness and resulting difficulty in machining is necessary to resist surface fatigue due to the contact stresses. This all also leads into why surface finish is important. I had to go back and look it up, but surface finish has a direct correlation to fatigue endurance limit (the [tex]C_s[/tex] Cs value in my book).
  • · Replies 17 ·
10K
  • · Replies 24 ·
11K
