| Thread Closed |
Neurogensis |
Share Thread |
| Apr3-06, 03:35 PM | #1 |
Neurogensis
Does anyone know what neurogensis is?
How is it related to human memory function?~Kitty |
| Apr3-06, 04:55 PM | #2 |
Hello,
The best way of learning new term is to go to www.google.com, type Define:yourword. http://www.google.se/search?hl=sv&q=...ogenesis&meta= After that you could try just typing the word itself. http://www.google.se/search?hl=sv&q=...S%C3%B6k&meta= I tell you this because neurogensis (the production of new nervous tissue) is a rather complex (and rather new) subject and requires a lot to write to make it clear to the reader. |
| Apr3-06, 05:31 PM | #3 |
Memory and neurogenesis is a little different. Memories are held by fixed glial cells, see axiom (myelin sheath) for an idea how glial function for set responses as a function and neurogenesis is more of the routes taken and the growth thereof.
The brain as a topic was my first paper but I will not go to far without direct questions and I can point you to information to reach a conclusion. For neurogenesis itself try single cell application look at how tubules within a cell acts almost like the central nervous system to a single cell. No…… this pursuit is not new... http://www.sdbonline.org/fly/aimorph/maltubls.htm#dafka What is neat is how the information is conveyed; note the width (nm) of the tubules and then the molecular structures themselves … there is a key within this…. |
| Apr4-06, 01:51 PM | #4 |
Recognitions:
Neurogensis
Most likely this thread will get moved over to the mind and brain sciences section and there you can find some more info on neurogenesis. I also recently did a review of an article on adult neurogenesis and memory function in that section. In that I provided some introductory material that may help you out.
In short, the term can be defined as the creation of nerve cells. This occurs primarily during development in the womb, but also some in early postnatal life and it continues in specific regions of the brain throughout adult life. As far as how it relates to memory, it's still a topic of investigation but neurogenesis does occur in regions of the brain that are also associated with memory and learning, ie the hippocampus. There are other processes/phenomena such as synaptic plasticity, budding that probably also play a role in memory function in the brain. |
| Apr4-06, 02:12 PM | #5 |
Recognitions:
| Apr4-06, 02:55 PM | #6 |
I'm going to back up DocToxyn here and ask that you provide a reference for your statement that memories are held in fixed glial cells, as that sounds a bit off-the-wall to me! As DocToxyn already explained well, neurogenesis is a term referring to the formation of new neural cells. Learning and memory are an area of research where it is hypothesized neurogenesis plays an important role in adults, so you can find published studies that discuss neurogenesis pertaining to that field of research, but that is not part of the definition of neurogenesis, but rather a probable function of the neurogenesis that continues in adulthood. |
| Apr4-06, 05:10 PM | #7 |
Neurogenesis is not new. That site showed that neurogenesis has been around while.
Neurogenesis and memories is where I was communicating and the Doc may understand what he feels is correct. Or of a hypothesis and all I did was share an example of where Glial function in a reoccurring or memory event. Just because it does not recall an event in time like in psychology, the same function of reigniting ‘its’ same event is in myelin sheath or as some call it muscle memory. What was the Glial count of Einstein’s brain mass? Take a look. Memories can continue to develop, neurons don’t as a general rule, neurons wire up the system and hold the base memories until sleep, that is when we use our energy to hard wire the memories within our Glial, please run through the research, I have no reason to bs. My first work at age 15 was on the brain in 82’, please don’t play games let’s articulate and we may both learn a bit, I am never to proud to learn. I would love to have you show me how it works. |
| Apr4-06, 07:42 PM | #8 |
| Apr5-06, 10:57 AM | #9 |
Recognitions:
Exactly how they do this is still under investigation. That said, I'm still having trouble with your statement about "hard wiring memories into glia", can you elaborate. I'm not sure if this is me just not being able to understand you posts or that you're confused regarding the literature you have read, maybe both... Can you help me out...what's your backgound in neuroscience, is english your first language? I'm not trying to berate or interrogate you, just trying to get a feel where you're coming from. |
| Apr6-06, 09:08 AM | #10 |
For the moonB
The brain of Albert Einstein has often been a subject of research and speculation. Einstein's brain was removed within 7 hours of the death of the famous physicist Einstein's brain also contained 73 percent more glial cells than the average brain http://en.wikipedia.org/wiki/Albert_Einstein's_brain Hello Doc, thanks for at least looking at my comment. Glial are fixed upon having a duty offering a refractive property. The molecular make up will assist in this. |
| Apr6-06, 11:48 AM | #11 |
Diamond MC, Scheibel AB, Murphy GM Jr, Harvey T. On the brain of a scientist: Albert Einstein. Exp Neurol. 1985 Apr;88(1):198-204. And, the analysis was only done on a SINGLE 6 or 20 micron section from each area! However, there were MAJOR flaws to this study and the conclusions drawn from it. First, the "controls" were not age-matched. There are differences in neural and glial composition of the brain with aging. Second, and more importantly, the study reports ONE of those 4 areas as having a statistically significant different "ratio" of glial to neuronal cells, yet, anyone with even a basic course in statistics knows you cannot do a statistical test when your "experimental group" consists of only ONE subject. Even worse, given the number of comparisons they did (their statistical approach was atrocious!...it was clearly a fishing expedition), they did not apply Bonferroni's corrections to those statistics (however they managed to arrive at them), which means even what they called significant is not. It's especially interesting that they find a significant ratio without finding a significant difference in absolute cell counts, which suggests there was truly no difference until they started playing with the numbers. For the detailed discussion of the flaws, see this later article: Hines T. Further on Einstein's brain. Exp Neurol. 1998 Apr;150(2):343-4. http://www.ncbi.nlm.nih.gov/entrez/q...&dopt=Abstract The original study and its flaws are also presented here in less technical terms: http://staff.washington.edu/chudler/ein.html Also noteworthy is that Einstein's brain was stored in formalin for several months, then embedded in celluloidin and stored in alcohol until the time of study. Formalin is a very harsh way to store brain tissue, and neuronal morphology is severely compromised in such tissue (I know this from first-hand experience working with post-mortem brain tissue preserved in that manner), which would also compromise the ability to accurately count neuronal density after such a long period of preservation (the best preservation of morphology in animal tissues is obtained with less than a 24 hour period of fixation after perfusion, and subsequent storage in the freezer in a cryoprotectant solution). Celluloidin embedding and storage in alcohol also leads to a substantial shrinkage of the tissue, introduction of embedding artifacts, and dehydration. The decades of storage alone could lead to quite substantial differences from more recently collected tissues. |
| Apr6-06, 12:42 PM | #12 |
Hey thanks for the depth and clarification regarding Einstein’s brain.
As for resources well I use everything and I googled up Einstein’s brain to see if that info was readily available for you but I feel you spent much more time to make your point. Before we can tackle the Glial question can we agree on this below, first? Just too make sure I am not working from bad information. I wrote this up just for you since you cared enough to help me with the big ‘E.’ Glial cells are the most numerous cells found in the brain. There are 2 familiar types’ astrocytes and oligodendrocytes of the macroglia variety. A type of Glial or microglia derived from the monocytes which grow in bone marrow can be specialized macrophages. These types are found throughout the body fluids. Glial appear similar to neuron with dendrites but they have a few distinct differences; they do not generate action potential or release neurotransmitters yet maintain the ability of mitosis unlike neurons. In a mature state they are fixed to a specific site and lose this mitosis state. They are heavy with the alkali metals such as K, Na and C. Astrocytes are the largest of the Glial numbering approximately 10 to 1 of the neuron cell count. They are star shaped when free but will adhere to neurons as to repair or stabilize a neuron and become a support addition with a variety of shapes. Glial can communicate independently of the neural network but the speed is far slower within astrocytes although they complement the neuron transmissions. They also tend to be ever present in and around synaptic connections. Oligodendrocytes are the most abundant of the Glial cells numbering over 50 to 1 over the neuron cells. They are most abundant as an outgrowth creating the myelin sheath separated by nodes of Ranvier. The Glial cells also show to bind groups of axons and support a structure for the collective. Is this OK? |
| Apr6-06, 06:26 PM | #13 |
| Apr7-06, 11:08 AM | #14 |
Oct 2005 Publication http://www.ncbi.nlm.nih.gov/entrez/q...&dopt=Abstract Expression and modulation of an NADPH oxidase in mammalian astrocytes. Thus, the NADPH oxidase is expressed in astrocytes and is functional, activated by PKC and intracellular calcium, modulated by pHi, and upregulated by astrocyte activation. The astrocytic NADPH oxidase is likely to play important roles in CNS physiology and pathology IN other words they see the pattern but have still yet to determine the full purposes. Or to see another http://www.ncbi.nlm.nih.gov/entrez/q...&dopt=Abstract this shows a high oxidation molecule that offer a similarity to the white blood These cells are very important in many areas of the body and have more than just a few functions and my point still stands regarding memories but we need to get by these basics. |
| Apr7-06, 09:01 PM | #15 |
| Thread Closed |
