Constructing an Energy-Collecting Apparatus for Physics Experiment
The discussion revolves around constructing an energy-collecting apparatus designed to concentrate energy from a 250 Watt heat lamp to heat a mass of water. The setup has specific constraints regarding height and accessibility for the water canister.
  • Participants suggest using a parabolic reflector to enhance energy collection. Questions arise regarding the optimal positioning of the reflector in relation to the heat lamp and the water canister.
Participants are exploring different configurations for the reflector and discussing its placement relative to the canister. Some guidance has been offered regarding experimentation with a visible source to determine effective positioning, but no consensus has been reached.
Constraints include the fixed height of the heat lamp and the maximum height of the apparatus, as well as the requirement for easy access to the film canister.
dragos
The purpose of this experiment is to construct an energy-collecting apparatus to concentrate as much energy from a provided 250 Watt heat lamp as possible. This energy is to be used to heat a mass of water. (the water will be given at a fixed temperature in a 35 mm film canister).
The heat lamp will be positioned 1.2m above the floor and the construction of the apparatus can't be higher then 0.9m, and the film canister should be easily put in the apparatus and taken out.
Anyone have any ideas?
please help...
A parabolic reflector (or two...) comes to mind
parabolic reflector
ic.. but where should i position the parabolic reflector, since i can't do anything to the lamp given in this experiment.
-as i understand I am supposed to build some kinda box that will attract as much heat as possible in order to heat the water.
The reflector should be below the canister, which must be a bit further away from its focus. Since you know the dimensions of the setup you can experiment with a visible source (candle?) to locate the optimum point.
19K
  • · Replies 67 ·
  • · Replies 16 ·
15K
35K
16K
