Solving Newton's Gravity Equation: Acceleration & Masses
  • Context: Undergrad
  • Thread starter Thread starter napoleonmax
    Acceleration Gravity
The discussion revolves around Newton's gravity equation, specifically the calculation of acceleration due to gravitational attraction between two objects of different masses. Participants explore the implications of using different approaches to derive acceleration, including whether to consider the sum of the masses or each mass individually. The scope includes theoretical reasoning and conceptual clarification regarding gravitational forces and accelerations.
  • One participant questions whether to use the sum of the masses or both masses individually to calculate acceleration, presenting two different equations for consideration.
  • Another participant asserts that the correct approach is to use the individual mass for acceleration calculations, stating that acceleration is independent of mass when considering gravitational attraction.
  • Some participants discuss the implications of large masses, such as Jupiter, and how they would affect the perceived acceleration of the Earth towards them compared to smaller masses like a car.
  • There is a mention of the need to account for both objects' accelerations when they are of similar mass, suggesting a more complex interaction than when one mass is significantly smaller than the other.
  • A participant introduces the concept of using a reference frame at the center of mass for more accurate calculations when dealing with massive bodies.
  • Another participant emphasizes that the principle of superposition can be used to find the force on an object from multiple bodies, leading to the conclusion that acceleration remains independent of the mass of the test body.
Participants express differing views on the correct method for calculating acceleration due to gravity, with some asserting that acceleration is independent of mass while others suggest that the sum of the masses should be used in specific cases. The discussion remains unresolved regarding the best approach to take in different scenarios.
Participants highlight limitations in their reasoning, particularly when dealing with objects of similar mass and the necessity of choosing appropriate reference frames for accurate calculations. There is also mention of the independence of acceleration in free-fall, which may depend on the context of the problem.
napoleonmax
I was thinking about Newton's gravity equation:
F = G * m(1) *m(2) / r^2. I wanted to find the acceleartion due to gravitational attraction that would occur between two objects of different masses so I used the equation F=ma. Then I ran into difficulty: should I use the sum of the masses to solve this or should I use both masses individually. In other words should my acceleration equation be a= F / m(1) + F / m(2) OR
a = F / [m(1)+m(2)] ? Which one is correct, if any? Clearly the two are not equal (if m(1) is 4 and m(2) is 3 then by the first equation the acceleration will be F/4 + F/3 which is 7F/12 and by the second equation the acceleration is F/7). Another problem is that these equations would allow heavier things to fall faster to the Earth (though only significantly on a large scale). That is, the moon would fall faster toward the Earth than would a car because the change in the force would exede the change in the mass. I would appreciate any help on the matter.
F=ma is indeed symmetrical with respect to gravitational attraction. So when you jump out of a plane, the force accelerating you down toward the Earth is also accelerating the Earth up toward you.
And yes, a veeeeery large object would not accelerate at G - G works only for objects which are an insignificant fraction of the mass of the Earth (ie, it works pretty well for anything this side of celestial mechanics).
Neither is correct. The right way is to use a1 = F/m1.
Using the correct equations, you'll find that acceleration is independent of mass. Thus, if they were at the same distance from the earth, the car and the moon would have the same acceleration. Does this help?
What if you put Jupiter at that distnce from the earth? Will the acceleration still be the same?
Oh no! :smile: Well, if Earth exerts the same gravitational force on Jupiter that Jupiter exerts on Earth...
The acceleration of Jupiter towards the Earth would be the same as a car and the moon, yes. BUT, the acceleration of the Earth towards Jupiter would be substantially larger than than the acceleration of the Earth towards a car!
Therefore, for an observer on Earth, Jupiter would APPEAR to accelerate faster.
It seems counter-intuitive but it does indeed work out that way.
If you calculate the gravitational force between the Earth and Jupiter,
[tex]F_g = \frac{G M m}{r^2}[/tex]
and then calculate Jupiter's Acceleration toward the earth,
[tex]a = \frac{F}{m}[/tex]
it comes out the same as any other mass, large or small, at the same distance. That is what you are doing when you use the equation,
[tex]a_g = \frac{G M}{r^2}[/tex]
After all,
[tex]m a = \frac{GMm}{r^2}[/tex]
I made a web page which gives a similar problem. I used two objects of the same mass though. It is not difficult to extend to different masses. Please see bottom of this web page
http://www.geocities.com/physics_world/gr/grav_field.htm
To find the force on an object simply use the principle of superpostition, i.e. add the forces on the "test" body which result from all the other bodies. You'll find that if the other bodies don't move then the acceleration on the test body is independent on the mass of the test body.
My point was just that the simplifications you can use for two objects of vastly different mass don't work so well with two objects of similar mass. Whether you drop a bowling ball or a car out of a plane, it works fine to consider the Earth completely stationary (not accelerating toward the plane). But when you drop the moon out of that plane, you need to account for both accelerations and probably pick a better reference frame (at the center of mass of the system for example).
Yes. Excellant point of course. Funny that people rarely aks that question. I was posting a forum in the late 90's called Ask Dr. Neutrino and recall a person asking that very astute question and recall in discust that he was flamed for it.
independence of acceleration in free-fall demands that the falling object be a test particle, i.e. that it is pointlike and has a mass which may be neglected in comparison to the source of the field. To obtain the answer that you seek you can simply replace the mass of the source with the sum of the masses of the two particles. I.e. suppose the two particles are constrained to move along the x-axis. Then it can be shown that
[tex]A = \frac {G(m_1 + m_2)} {R^2}[/tex]
where A is the relative acceleration of the two particles and R is the distance between them.
For derivation please see
http://www.geocities.com/physics_world/mech/two_accel.htm
Integral - Thanks for showing me that! :-)
.. should I use the sum of the masses to solve this ..
Yes. Use the sum of the masses. But note that this applies to a special case of the particles moving along a line.
You are of course correct that when talking about the acceleration with respect to the earth of a massive body, then the acceleration of the Earth must be factored in. I was taking an inertial frame as my reference point (silly me).
For straight line motion, it's trivial (as Arcon points out). My advice to napoleonmax is to keep it simple. Find the accelerations of each using an inertial frame (where F=ma), then add them to get the relative acceleration. This results in napoleonmax's first equation:
Yes. That gives the correct relative acceleration.
Edit: included quote by napoleonmax and comment.
Its just that Earth is the reference frame people are used to. When they get a situation where the Earth isn't really able to be considered stationary, it throws them a curve. In some cases, Earth can be considered an inertail frame, in some it can't.
  • · Replies 39 ·
  • · Replies 20 ·
  • · Replies 21 ·
