Dimensions of Sin(wt) and Sin(w) and Sin(t)
  • Thread starter Thread starter VooDoo
    Dimensions
The discussion revolves around the dimensions of the sine function applied to angular velocity and time, specifically examining whether sin(wt), sin(w), and sin(t) are dimensionless. The context includes engineering applications and mathematical reasoning related to trigonometric functions.
  • Some participants assert that sine functions must have dimensionless arguments, suggesting that sin(a) can only be calculated if a is dimensionless.
  • Others argue that while w (angular velocity) has dimensions of 1/T and t (time) has dimensions of T, radians are often considered dimensionless, leading to the conclusion that the argument wt is dimensionless.
  • A participant points out that the units of the sine function depend on the context in which it is used, providing examples such as air pressure and voltage where sin(wt) could represent different physical quantities with specific units.
  • Another participant emphasizes that the output of trigonometric functions is dimensionless, as they represent ratios of lengths, but suggests that keeping track of units can be helpful in certain derivations.
  • There is a mention of the importance of converting angular velocity from revolutions per minute to radians per second, highlighting the relationship between angular measurements and their representation in trigonometric functions.
Participants express differing views on whether sin(wt), sin(w), and sin(t) are dimensionless. While some agree that the arguments must be dimensionless, others provide counterarguments regarding the context and units involved, indicating that the discussion remains unresolved.
There are unresolved assumptions regarding the definitions of dimensions and the treatment of radians in trigonometric functions. The discussion also highlights the potential for confusion when applying these concepts in practical engineering contexts.
VooDoo
Hi guys,
Hi guys,
We are working with dimensions of equations in engineering, I do not completely understand the dimensions of sin(wt) and sin(w) and sin(t), are these all dimension less?
w=angular velocity therefore dimensions of 1/T.
t=time therefore dimensions of T
The amplitude of the periodic motion will establish the units. Most of the time, the units will be a displacement. You don't actually show the implied amplitude of 1.
As far as I know you can't take the sin of a dimension so sin(a) will always be dimensionless and can only be calculated if a is dimensionless as well. (This is just common sense telling me this so if anyone has any information to the contrary correct me)
Like FredGarvin said it is the coefficient of the sin function that will determine the units.
Not exactly. w has units of radians per second. t has dimensions of seconds. I think that radians are generally considered to be dimensionless, or call it units of [1].
It's not a sufficient question to ask what units sin(wt) has. It depends on the quantity that you are using that function to represent. For example,
Air pressure -- P = P1 * sin(wt) could have units of N/m^2
Voltage -- V = V1 * sin(wt) would have units of Volts
The argument wt to the sin function is in radians in this form. Make sense?
VooDoo said:
Hi guys,
Hi guys,
from Aditya Sonkar
it's not dimension less
VooDoo said:
Hi guys,
Hi guys,
w is for lower case omega, the angular velocity, in radians per second.
When working with your homework problems, you will often be working with revolutions per minute. Showing how to convert to radians might be illustrative here.
One revolution is 2*pi radians.
Radians are said to be dimensionless because the trig functions are defined as having radians as their argument. There is no conversion factor once you are in radians, it is what I would call a "pure measurement". I would be interested in what a real mathematician would call it.
rev = 2*pi radians
rpm = rev / min
= rev / [(60 sec / min) * min]
= rev / (60 sec)
= 2*pi radians / (60 sec)
rpm= 2*pi radians / (60 sec)
rpm= pi radians / (30 sec)
Which let's us create a conversion factor:
rpm/[ pi radians / (30 sec)] = 1
30*pi*rpm/sec = 1
The radians have been dropped ("dimensionless") because the definition of the trig function it will be plugged into is defined in terms of radians. You could keep writing it as part of the conversion factor, but most people don't.
So if you are given 33 rpm and you want the angular velocity you use the conversion factor:
w = [30*pi*rpm/sec] / (33 rpm) = [(30*pi)/33] 1/sec
so we can directly find the angular velocity from the rpm.
If you plug just w into the sin function, it gives an error because the argument should be in radians but you're giving it a value in inverse seconds. But multiply w by the variable t=time and the function generates the familiar sinusoidal shape.
So you can either keep writing 'radians' in the conversion factor, and then you plainly see that w is in radians/second and w*t is radians. Or you can quit writing it out and just realize that you're treating the radians value as a pure number, and that your function is defined to interpret that pure number as a value measured in radian.
One revolution is also 360 degrees, so if you can convert from degrees to radians by
2*pi radians = 360 degrees
duh, you knew that.
hth
The input of any transcendental mathematical function must be a dimensionless number and so is its output. That being said, out of [itex]\omega t[/itex], [itex]\omega[/itex] and [itex]t[/itex], which one is dimensionless?
Sine, cosine, etc. are functions with one argument that must be an angle. Angles are considered dimensionless, but from my experience, it is a good idea to always keep them when deriving functions, as it is sometimes more helpful to understand what you are looking at. For example, it can be helpful to see the SI unit of torque as N.m/rad instead of just N.m (which is the unit for energy), such that:
Torque = Energy / angle displaced [ = N.m / rad ]
Power = Torque * angular velocity [ = N.m/rad * rad/s = N.m/s ]
So for a internal combustion engine, the power is the energy per angle displaced times the angular velocity. The energy can be calculated from the fuel burned, the angular velocity is the rpm, but the angle displaced will be 1 revolution (2PI rad) for a 2-stroke and 2 revolutions (4PI rad) for a 4-stroke.
The output of the trigonometric functions are purely dimensionless as they represents the ratio of one length over another:
sine = opposite / hypotenuse
cosine = adjacent / hypotenuse
etc.
  • · Replies 20 ·
