Why do stars exhibit red shift and blue shift in our universe?
  • Context: Undergrad
  • Thread starter Thread starter shaan_aragorn
    Universe
The discussion revolves around the concepts of gravitational forces in a finite universe, the implications of a rotating universe, and the nature of red shift and blue shift observed in stars. Participants explore theoretical frameworks and interpretations of Stephen Hawking's ideas, as well as the dynamics of celestial bodies within the universe.
  • Some participants argue that if the universe is finite, gravitational forces would eventually pull all matter toward a center of mass, regardless of the strength of the pull.
  • Others challenge this notion, suggesting that a rotating universe could maintain a static appearance without collapsing into a single point.
  • There is a contention about whether a universe can be considered static if it is rotating, with some participants questioning the implications of constant angular momentum on celestial orbits.
  • A participant introduces an analogy involving magnets in a vacuum to explore the concept of attraction over infinite distances.
  • Some participants clarify that Hawking's proposal of a finite universe does not imply it has definable boundaries or a center.
  • It is noted that the universe is isotropic and homogeneous, with red shift and blue shift observed in stars indicating their movement relative to Earth.
Participants express multiple competing views regarding the implications of a finite universe and the nature of gravitational forces. The discussion remains unresolved, with no consensus on the interpretations of Hawking's ideas or the dynamics of the universe.
Participants highlight the need for clarification on the assumptions made about the universe's static or dynamic nature, as well as the definitions of rotation and gravitational influence in a cosmological context.
shaan_aragorn
In his book "The Brief History Of Time", Stephen Hawking says that if the universe is finite, as assumed by Newton et al, the astronomical bodies would fall on one point. Now I am having a really tough time imagining this. Wouldnt the gravitational force be too weak to pull these bodies on one point over such enormous distances?
Astronomy news on Phys.org
No. In order for that to be correct, the gravitational pull would have to be exactly zero. Otherwise, with any net pull, regardless of how small, the matter in the universe would eventually fall to the center of mass. The strength of the pull just determines how long it takes.
The key is that if the universe started static and had a center, every object would have some net force pulling it toward that center. It wouldn't stay static for long.
That's not true. It could rotate, the way the planets in the solar system do. Those aren't going to fall into the sun, and they're not expanding their orbit either.
Are you postulating that the universe itself is rotating?
The reason our planets orbit the sun without being 'pulled' towards it, is because the sun's mass is relatively static which means it's gravitational pull on our solar system is also relatively static.
How can a universe rotate and still be considered static? Can a universe, by definition, even be rotating?
Also, merely rotating wouldn't be enough: that implies a constant angular momentum, and with a constant angular momentum, you only get an orbit at one specific radius - every object further away spirals out and every object closer in spirals into the center. Or maybe some just end up in highly elipitcal orbits - my celestial mechanics isn't that great. Either way, it's tough to call that situation "static".
Is this situation analogous to two magnets (or charges/poles) kept in vacuum with zero gravity (for cutting out external effects)? Will such two magnets also attract each other (assuming they are of opposite polarities) over an infinite distance?
I was simply objecting to the notion that "if the universe is finite, it must fall on one point." I never said anything about it being static. I'm also not actually postulating that it is actually rotating (as in, ever object is rotating around a common center of mass), I simply wanted to point out that such a situation is possible.
Hmm - rereading the OP, I think we'll need to clarify what Hawking was talking about. I assumed he also meant static. The question seems to be asking why the universe couldn't be static.
Hawking proposed the universe is finite, but unbounded, in his book. He never intended to infer the universe is finite in the sense of having definable boundaries [or a center].
The universe is isotropic and homogenous. The universe, when viewed on sufficiently large distance scales, has no preferred directions or preferred places. Stars exhibit red shift and blue shift when observed from the Earth but a majority of them exhibit red shift, indicating that the stars are moving away. This observation will be true from any region of the universe.
  • · Replies 23 ·
