Creating a Prime Sieve with Boolean Expressions
  • Context: Java
  • Thread starter Thread starter JasonRox
    Expressions Prime
This discussion focuses on creating a prime sieve using boolean expressions in programming. The user seeks guidance on initializing a large array of boolean variables to classify numbers as prime or non-prime. The solution provided involves declaring an integer variable X to define the size of the boolean array, followed by initializing it with the syntax boolean [] p = new boolean[X];. This approach allows for efficient classification of numbers in the sieve algorithm.
  • Understanding of boolean data types in programming
  • Familiarity with array initialization in Java
  • Basic knowledge of prime number algorithms
  • Experience with loops and conditional statements in programming
  • Implement the Sieve of Eratosthenes algorithm in Java
  • Explore optimization techniques for prime number generation
  • Learn about memory management in large arrays
  • Investigate alternative data structures for prime sieving
Programmers, computer science students, and anyone interested in algorithm optimization and number theory will benefit from this discussion.
JasonRox
I'm trying to create a sieve (prime sieve). A nice quick simple one using boolean expressions.
I remember on Visual Basics it began by creating like X number of boolean variables and then sieve them out by classifying them as false... and so on.
How to a create a large group of boolean variables?
I think it was something like p(i) and i=X, which X determined how many to create. It was something like this I think.
So, technically i is like a variable itselt because when I go through the loop, I should be able to go through steps like...
p(4) = false;
p(6) = false;
p(8) = false;
... all the way until I reach 2X.
So, how do you create this variable?
Thanks, I appreciate it.
Technology news on Phys.org
Create as big of an array as you like.
int X = 1000 ;
Thanks a lot.
I'll see how it turns out.
11K
