Why Does Reflecting a Point Twice Across Parallel Lines Double the Distance?
  • Context: High School
  • Thread starter Thread starter terpsgirl
    Transformation
The discussion centers on the geometric transformation of reflecting a point across two parallel lines that are ten inches apart. When a preimage is reflected twice through these lines, the final image is located twenty inches away from the original preimage. This conclusion is derived from the fact that each reflection effectively doubles the distance between the preimage and the final image, resulting in a total distance of twenty inches after two reflections.
  • Understanding of geometric transformations, specifically reflections.
  • Familiarity with parallel lines and their properties.
  • Basic knowledge of distance measurement in geometry.
  • Ability to visualize transformations on a coordinate plane.
  • Study the properties of reflections in geometry.
  • Learn about transformations involving multiple reflections.
  • Explore the concept of distance between points in geometric transformations.
  • Investigate the implications of transformations on coordinate systems.
Students studying geometry, educators teaching geometric transformations, and anyone interested in understanding the principles of reflections in mathematics.
terpsgirl
a transformation question? HELP PLS
Hi, I have this question from classwork and I can't quite figure it out. I know its very simple, but I can't quite understand it...
If two parallel lines are located ten inches apart, a preimage that is reflected twice through those lines will be _________ inches away from the final image.
** I know the answer is twenty, but I'm not sure how/why.
Could someone help in explaining? It would be very appreciated!
Thanks
Mathematics news on Phys.org
check out the attached file. i hope it will be clear from the picture. if not then feel free to tell me. you can also pm me or mail me at murshid_islam@yahoo.com.
Thanks
"Reflected twice through those lines"? I will assume that that means "reflected in each of the lines".
Imagine a point x inches from the first line (for simplicity, take x< 10 and the point is NOT between the two lines). After one reflection, the (image of the) point will be on the other side of the line (and so between the two lines) at distance x inches from it. What distance will it be from the second line now? Call that distance y. After the second reflection, the point will be on the other side of THAT line and the same distance from it. Okay, the total distance will be the original x inches plus the x inches on the other side, plus the y inches the first image was from the second line plus the y inches it was reflected to. What do all those add to?
Now see if you can do it assuming the original point is between the two lines or if it is more than 10 inches from the first line.
  • · Replies 16 ·
