Does Linear Algebra Prove Mutual Exclusivity of Transformation Properties?
The discussion revolves around a linear transformation T: V->V, where V is a finite-dimensional vector space. Participants are tasked with showing that exactly one of two conditions holds: either T(v) = 0 for some non-zero vector v in V, or T(x) = v has a solution x in V for every vector v in V. The focus is on understanding the implications of these conditions and their mutual exclusivity.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the implications of the conditions, questioning whether the truth of one condition necessarily negates the other. There are attempts to clarify the definitions and assumptions behind the conditions, with some participants expressing confusion over the logical connections between them.
The discussion is ongoing, with participants actively questioning the reasoning presented and seeking clarification on the implications of the conditions. Some guidance has been offered regarding the interpretation of the problem, but no consensus has been reached on the logical structure or the necessary proofs.
There is an emphasis on the nature of the linear transformation T, particularly regarding its behavior at the zero vector and the implications of having a non-zero vector mapped to zero. Participants are also grappling with the definitions of solutions in the context of linear transformations.
stunner5000pt
Let T: V->V be a linear transformation where V is finite dimensional. Show ath exactly one of (i) an (ii) holds
i) T(v) = 0 for some v not zero in V
ii) T(x) = v has a solution x in V for every v in V
do they mean that if i holds then ii cannot hold?
Ok suppose i holds
T(v) = 0 for some v in V, v not zero
then T(T(v)) = T(0) = 0
let T(v) = x
then T(x) = 0
only solution here is x = v
So T(x) = 0 for all x. ANd thus is not possible for T(x) = v if T(v) = 0
There's more to it than that...
Anyways, your proof doesn't make any sense to me: here are the problems I see:
let T(v) = x
Okay. I don't see the point of defining x to be zero, though.
then T(x) = 0
(1) Solution to what?
(2) For what are you solving? You haven't written down any unknowns!
(3) Why is it a solution?
(4) Why is it the only solution?
You've defined x to be T(v) (which is zero) -- so it doesn't make sense to say "for all x".
Clearly i missed the point of the question
what are they asking for actually?
i imples that ii cannot h0old and vice versa?? Is that what I am aiming for here?
Let T: V->V be a linear transformation where V is finite dimensional. Show that exactly one of (i) an (ii) holds
"Show that exactly one holds" means "one of these and only one" You must show that for any vector v either (i) is true or (ii) is true and also show that they can't both be true.
What do you know about T(0)? If (i) is true, if T(v)= 0 for non-zero v, then what is the solution to T(x)= 0?
isnt T(0) = 0
suppose T(v) = 0, then if T(x) = 0, then x = v
stunner5000pt said:
isnt T(0) = 0
Did you notice the emphasis in the solution?
Yes, T(0)= 0. Don't you see a problem with that and "T(v)= 0 for some no-zero v"?
so
suppose T(v) = 0 for v not zero
then suppose T(x) = 0, for some x in V then x =v.
But T(0) = 0 , so x must be zero? But v is non zero. SO the second one cannot hold? Is it like that?
In general, T(x) = T(y) does not imply x = y.
right, T in this case is not specified to be one to one
so for T(x) = 0 ,x MUST be v because of the assertion of the first condition.
Why do you think (i) tells you x = v?
  • · Replies 24 ·
