| Thread Closed |
MS-PROMPT commands |
Share Thread | Thread Tools |
| Dec28-03, 12:11 PM | #1 |
MS-PROMPT commands
anyone knows where to get a list of all the ms-prompt commands ?
| Dec28-03, 12:39 PM | #2 |
run the command "help"
| Dec28-03, 10:49 PM | #3 |
Specified COMMAND search directory bad
Microsoft(R) Windows Millennium (C)Copyright Microsoft Corp 1981-1999. i only got this when i typed "command help" and "bad command bad file name " when i type "help" |
| Dec29-03, 01:13 AM | #4 |
MS-PROMPT commands
Works on my machine.
I get the sneaky suspicion you did exactly what you just said; you ran "command help" then ran "help". Try again, but just run "help"... "command help" does something else entirely, among other things, as I've tested here, it puts you in a shell without any of your environment variables set properly; in particular your path isn't set right, so when you subsqeuently tried to run "help", it didn't know the path to search. |
| Dec29-03, 02:13 AM | #5 |
it's the same.
i typed c:\help and got a message"bad command or file name" |
| Dec29-03, 02:26 AM | #6 |
Did you type "C:\help" at the Dos prompt or just "help". Just "help" by itself is what needs to be entered at the command prompt.
| Dec29-03, 03:38 AM | #7 |
just "help"
| Dec29-03, 03:41 AM | #8 |
"help" works for me as well.
Is there anything in particular you're trying to do, Vincent? |
| Dec29-03, 04:28 AM | #9 |
From start ->run, you could try entering "cmd.exe". If that doesn't work, see if a command prompt shortcut exists in your accessories folder on your start menu, if it does, start that.
Command.com (aka command) is the 16 bit ms-dos command intrepreter. cmd.exe is a 32 bit Windows application that emulates dos. Does Win ME have cmd.exe? |
| Dec29-03, 04:39 AM | #10 |
windows cannot find "cmd.exe".
| Dec29-03, 11:09 AM | #11 |
Some source: http://www.google.com and http://www.ee.usyd.edu.au/tutorials_.../dos-cmds.html
Some of this doesn't work in XP |
| Thread Closed |
| Thread Tools | |
Similar Threads for: MS-PROMPT commands
| How to define commands in CDB file for printout eigenmodes in ASCII format | Mechanical Engineering | 0 | ||
| DOES ANYONE KNOW WERE TO FIND a list of dos bacth file commands | Programming & Comp Sci | 6 | ||
| commands | Computing & Technology | 5 | ||
