Register to reply
Rate of change from 1 to 2 for f(x)=2x^3 + x
by Rusho
Tags: fx2x3, rate
Share this thread:
Rusho
#1
Apr8-06, 06:50 AM
P: 24
Find the average rate of change from 1 to 2 for the function f(x)=2x^3 + x
so I did this:
[f(2) f(1)] [2x^3 + x] / 2-1
= 2-1-2x^3 + x / 1
= 1-2x^3 + x
= -2x^3 + x
Right?
Phys.Org News Partner Science news on Phys.org
Hoverbike drone project for air transport takes off
Earlier Stone Age artifacts found in Northern Cape of South Africa
Study reveals new characteristics of complex oxide surfaces
Galileo
#2
Apr8-06, 06:53 AM
Sci Advisor
HW Helper
Galileo's Avatar
P: 2,002
The average rate of change of f from a to b is
[f(b)-f(a)]/(b-a)
and it's (naturally) just a number. It doesn't depend on x. Check your definition.
Rusho
#3
Apr8-06, 07:08 AM
P: 24
[2(2)^3 - 2(1)^3] - [2x^3 + x] / 2-1
16-1-2x^3 + x / 1
15-2x^3 + x
I don't understand what you are telling me
Galileo
#4
Apr8-06, 07:14 AM
Sci Advisor
HW Helper
Galileo's Avatar
P: 2,002
You've got the definition of the average rate of change wrong.
You wrote something like (f(2)-f(1)-f(x))/(2-1).
By definition, the average rate of change of f on the interval [a,b] is:
[tex]\frac{f(b)-f(a)}{b-a}[/tex]
So in your case, the average rate of change is:
[tex]\frac{f(2)-f(1)}{2-1}[/tex]
Rusho
#5
Apr8-06, 07:23 AM
P: 24
Ok, I am not sure what to do with 2x^3 + x . So I subtracted it from the f(b) - f(a).
If I had 2x^3 by it self, I can see just putting 2(2)^3 - 2(1)^3 / 2-1
but the "+x" is confusing me
Rusho
#6
Apr8-06, 07:53 AM
P: 24
I think I got it
2(2)^3 + x - 2(1)^3 + x / 2-1
=16-2+x+x / 1
=14+2x
=-2x + 14
x = -7
Galileo
#7
Apr8-06, 07:57 AM
Sci Advisor
HW Helper
Galileo's Avatar
P: 2,002
So you can solve it if the function is 2x^3, but not if it's 2x^3+x? What's the difference, conceptually?
f(x)=2x^3+x, so what is f(2)? And what is f(1)?
BobG
#8
Apr8-06, 09:36 AM
Sci Advisor
HW Helper
BobG's Avatar
P: 2,278
Quote Quote by Rusho
I think I got it
=16-2+x+x / 1
=14+2x
=-2x + 14
x = -7
Calculate f(2). Calculate f(1). Subtract the result of f(1) from f(2).
The solution for f(2) is not 16+x. You have to substitute '2' for x everywhere it appears, so the solution for f(2) is 16+2.
Also, your algebra is wrong (in addition to being not applicable in this case). If you have:
[tex](3x^2 + 3x) - (2x^2 + 2x)[/tex]
then the minus sign means both the 2x^2 and the 2x are negative:
[tex]3x^2 + 3x - 2x^2 - 2x[/tex]
[tex](3x^2 - 2x^2) + (3x - 2x)[/tex]
etc.
Rusho
#9
Apr8-06, 10:05 AM
P: 24
2(2)^3 + (2) -1 / 2-1
16+2-1 / 2-1
17/1
I'm sorry if I'm just not getting it
Galileo
#10
Apr8-06, 10:49 AM
Sci Advisor
HW Helper
Galileo's Avatar
P: 2,002
Alright, let's take some steps back.
You are given a function f. It's a machine that eats a number and spits out a (usually different) number.
f(x)=2x^3+x tells you the value of the function at each point, it's an equality that holds for each number x.
For example:
f(1)=2(1)^3+1=2+1=3
f(5)=2(5)^3+5=2(125)+5=255
So if you want to calculate [f(2)-f(1)]/(2-1) you have to calculate f(2) and f(1). I already did f(1) for you above. Now you do f(2) and calculate [f(2)-f(1)]/(2-1)
Rusho
#11
Apr8-06, 11:00 AM
P: 24
2(2)^3 + (2) - 2(1)^3 +1 / 2-1
=18-3 / 2-1
=15/1
=15
Galileo
#12
Apr8-06, 11:29 AM
Sci Advisor
HW Helper
Galileo's Avatar
P: 2,002
Right that's correct.
BTW: Mind your brackets: -2(1)^3+1 is not the same as -(2(1)^3+1)
Rusho
#13
Apr8-06, 12:32 PM
P: 24
Great! Thanks for your help!
I have another one, maybe I should start a new post
Register to reply
Related Discussions
Rate of change Calculus 1
Related Rate -finding the Rate of Change of an Angle Calculus & Beyond Homework 5
Rate of change Introductory Physics Homework 5
Measuring rate of reaction via rate of temperature change Chemistry 3
Rate of change General Math 3
