Unlocking Nature's Hydrogen: An Inexpensive Metal Catalyst
The discussion revolves around the use of a metal catalyst for splitting water into hydrogen and oxygen, exploring various methods and reactions involving metals and water. Participants share their thoughts on the feasibility of these reactions, the types of metals involved, and the implications of using hydrogen as a fuel source.
  • One participant mentions a cheap metal catalyst that can split hydrogen and oxygen when interacting with water, seeking further information for experimental purposes.
  • Another participant describes a method where heating metals and submerging them in water produces hydrogen and oxygen, but questions the reliability of this method at standard temperature and pressure (STP).
  • A different participant challenges the initial claim, suggesting that the production of hydrogen gas is more feasible with certain active metals, such as sodium, which reacts vigorously with water.
  • Concerns are raised about the safety and control of burning hydrogen, with a participant noting that the heat generated from thermolysis could lead to explosive reactions.
  • Some participants discuss the potential of using hydrogen as a substitute for natural gas in grills, emphasizing the need for careful control of gas flow and mixing with oxygen.
  • Questions arise regarding the behavior of salts in seawater when reactive metals are introduced, with a focus on the potential for precipitation as water is consumed in the reaction.
  • One participant suggests the concept of photocatalysis as an alternative method for splitting water using visible light.
Participants express differing views on the effectiveness and safety of various methods for producing hydrogen from water. There is no consensus on the best approach or the reliability of the claims made regarding metal catalysts and their reactions.
The discussion includes assumptions about the conditions under which reactions occur, such as temperature and the activity series of metals. Some claims lack detailed experimental evidence or specific definitions, leaving room for interpretation and further exploration.
This discussion may be of interest to those exploring chemical reactions involving metals and water, hydrogen production methods, and the potential applications of hydrogen as a fuel source.
banerjeerupak
I have heard about this metal catalyst which splits hydrogen and oxygen on interacting with water. i was a bit surprised when i came to know that this is a cheap metal and readily available.
Can you give me the name of the metal catalyst so that i can conduct expt in my labs.
Chemistry news on Phys.org
I don't know if this is what your referring to, but if you heat metals up, really really hot, and stick them in water, it breaks the water down into Hydrogen gas and Oxygen gas. The Oxygen gas then Oxidizes the metal and the Hydrogen gas escapes into the atmosphere, but since it is so hot, then combusts with the Oxygen in the air.
I have seen this done in a video before, while someone is making a [samuri] sword, they heat it up red hot, then dunk it water, and you can see flames coming up out of the water.
I have never heard of a metal catalyst doing such at STP. banerjeerupak. are you sure that it wasn't from some crackpot place/site?
banerjeerupak, are you sure it produces both Hydrogen and Oxygen gas?
If you loosen the requirements to just producing Hydrogen gas, then it is easy. Just place a more active metal into water (a metal above Hydrogen on the activity series) and the metal will react to produce Hydrogen gas and a metal Hydroxide.
Sodium is an excellent example of this, put a chunk of Sodium metal into water and it will expload due to the intense heat of the reaction combustion the Hydrogen gas which is produced, leaving behind NaOH in solution.
If you look at the activity series, you can see that there are several fairly common metals that will do this, although the lower down you go, the slow the reaction becomes.
http://www.chem.vt.edu/RVGS/ACT/notes/activity_series.html
The alkili metals on the periodic table will easily replace the Hydrogen from water, alkiline Earth not quite as fast, and when you get really low, metals like Tin and Lead do it so slowing it is negligible.
ok i really think that i made a mistake. anyway it must have been just the production of hydrogen. another question has cropped up in my mind. that is if we can burn hydrogen without explosion. the hydrogen that has been released, would be an excellent source of heat.
Unfortunately it is very hard to control the burning of hydrogen. You /are/ right, it would be an excellent source of heat. since the thermolysis of water happens at 1500 C, reversing would obviously create huge amounts of heat. The thing is, that heat is probably one of the reasons hydrogen explodes rather than just burns. The only way I could think of would be to go slow on the oxygen to control the reaction, but I'm not sure if this is profitable.
I have heard of people using Hydrogen as a substitute for natural gas in grills.
In theory, it is possible as long as you control the flow of the gas and make sure not to mix it with Oxygen until it is ready to burn.
mrjeffy, what would happen to salt in this situation, as in seawater density 1.02 (or something)?
The situation of placing a much more reactive metal (like Lithium for instance) into water to release the Hydrogen?
The salt would remain behind in solution, assuming it does not react with the metal. The salt should not be affected by the reaction between the water and the active metal, the water will be split up, leaving a Hydroxide behind. Eventaully, it might get to the point where the remaining water will not be enough to keep everything in solution, so stuff might start precipitating out.
  • · Replies 19 ·
11K
  • · Replies 16 ·
