Finding the maximum height of an arrow shot in the air
The discussion revolves around a physics problem involving projectile motion, specifically the maximum height of an arrow shot vertically and the average acceleration of a bird in flight. The original poster presents calculations and seeks validation of their approach and results.
  • Mixed
  • The original poster attempts to calculate the maximum height of an arrow using a displacement formula and expresses uncertainty about the correctness of their method and answer. They also inquire about drawing vector diagrams to scale.
  • Another participant points out the importance of considering the negative acceleration due to gravity and notes an error in the original poster's final answer.
  • The original poster raises a new question regarding the average acceleration of a bird, providing their calculations and questioning the signs of their velocity components.
  • Further discussion includes guidance on drawing vector diagrams, emphasizing the importance of unit selection and proportional representation of forces.
Participants are navigating through potential errors in calculations and assumptions about vector components. The original poster's uncertainty about the formulas and the signs of their values indicates a need for clarification on these concepts.
christinaa_s
QUESTION: An archer shoots an arrow straight up in the air with an initial velocity of 45 m/s , it takes the arrow 4.6 s to reach its maximum height. Calculate this maximum height.
the α, ∆d, and vi should have arrows over them:
MY ANSWER:
displacement = ½ [(α ∙ ∆t + vi) + vi + vi] ∆t
therefore vi ∆t + ½ α t(2)
therefore ∆d = 207 + 103.68
therefore ∆d = 310.68 m
I'm not sure if i used the correct formula or if my answer if right.
Also, how do you draw vector diagrams to scale? :shy:
Remember that acceleration due to gravity is -g. Other than that all the other umbers seem fine apart from the error leading to the final answer.
(yes i forgot that this gravity should be negative, thanx!
another question i am not sure of!..
QUESTION: A bird takes 8.5 s to fly from position A (va= 4.4 m/s (3 ° S of E) to position B(vb= 7.8 m/s ( 25° N of E) along the path. Find the bird's average acceleration.
MY ANSWER:
vax = 4.4 cos 31
vay = -4.4 sin 31
vbx = -7.8 cos 25
vby = 7.8 sin 25
ax = vbx – vax / t therefore ax = -7.8 cos 25 - 4.4 cos 31 / 8.5 ?
ay = vby – vay / t therefore ay = 7.8 sin 25 + 4.4 sin 31 / 8.6 ?
therefore a = √ ax(2) + ay(2)
a = √ 1.5 + 1.06
a= 1.60 m/s ?
once again i am not sure if my answer is correct, and if vay/ vbx should be negative..
Imagine 2 forces..one has a magnitude of 4N and acts along the x axis, the other has a magnitude of 3N and acts along the y axis...before you start drawing decide on your units...does 1N = 1cm, 1 inch, 1mm? (Not so ridiculous if the magnitudes of your forces are well into double figures)...once you pick your units draw the horizontal one (the 4N one) once this is drawn just draw the vertical one but as it's 3N make sure that the length of this line is 3/4 the length of the horizontal one (and points vertically)...you should end up with the two smaller sides of a right angled triangle.
