The mass of the string is not needed to answer this question
  • Thread starter Thread starter Alt+F4
    Mass String
The discussion focuses on the physics of a string resonating between two supports, specifically analyzing its wavelength and frequency under varying tension. The wavelength is calculated as 0.8 m, derived from the formula L*2/3. When the tension in the string is increased by a factor of 4, the new frequency can be determined using the relationship between wave speed, tension, and density. The speed of sound is also discussed, with a calculation for frequency based on a distance moved towards a loudspeaker.
  • Understanding of wave mechanics and standing waves
  • Familiarity with the relationship between tension, wave speed, and frequency
  • Knowledge of basic acoustic principles, including sound intensity and frequency calculation
  • Ability to manipulate and rearrange equations in physics
  • Learn about wave speed calculations in different media
  • Study the effects of tension on string vibrations and frequencies
  • Explore the concept of mass density in wave mechanics
  • Investigate the relationship between sound intensity and distance from a source
Physics students, educators, and anyone interested in understanding wave mechanics and acoustic principles in real-world applications.
Alt+F4
A string is stretched between two supports that are L = 1.2 m apart. It resonates at a frequency of f = 450 Hz with a standing wave pattern that has two nodes between the two supports.
(a)Using the unit of m , find the wavelength l.
Wavelength = .8
I did 1.2*2 /3 which is the correct answer then
(b) Suppose that the tension, T, in the string is increased by a factor of 4. What is the new frequency, f', in unit of Hz , if the string vibrates with the same standing wave pattern that it began with (i.e. A standing wave pattern that has two nodes between the supports).
HELP: The wave length l is determined by the number of nodes, so it keeps unchanged; however, the wave speed is determined by the tension T and the string's density d = mstring/L, so it will change.
HELP: First, find the incresing factor of the wave speed v by using the equation of v2 = T/d, and then find the incresing factor of the frequency by using the equation of v = f l. Remember, l = l' because the number of nodes is same.
I don't know what the mass of the string is so how do i find it inorder to get desity? Thanks
Also this Problem
As you move toward one of the loudspeakers, the intensity decreases. When you have moved by 0.5 m , you hit the first point of zero intensity.
Assuming that the speed of sound is v = 330 m/s , what is the frequency f of the sound in Hz ?
okay The distance between two closest nodes in a standing wave pattern is lambda/2, where lambda is the wavelength. Hence, the distance from an intensity maximum to the closest node is lambda/4, which is the distance by which you have moved. This gives you lambda.
So what i did was .5/4 = .125
v=lambda*f.
330 = .125 f
Which is not the asnwer
The mass density of the string is the same (im guessing they don't want you to worry about the fact that the string will stretched lowering it's mass density). Think about how increasing the tension will SCALE the previous velocity and use that to find the new frequency.
for your second post, it looks like you made a typo. I think you meant to multiply by, not divide by four, to get the wavelength.
  • · Replies 29 ·
  • · Replies 23 ·
