Accelerator Experiments, Detector Mass & Gravity Effects
  • Context: Graduate
  • Thread starter Thread starter Thomas Larsson
The discussion revolves around the implications of quantum field theory (QFT) in the context of accelerating observers and the role of foliations in defining time and space within quantum frameworks. Participants explore the relationship between classical and quantum perspectives, particularly in accelerator experiments where gravity effects may complicate assumptions about mass and motion.
  • Some participants argue that time in conventional quantum mechanics is independent of events, while others suggest that the observer's trajectory is a quantum variable that introduces uncertainty into the definition of foliations.
  • There is a contention regarding the treatment of foliations in QFT, with some asserting that they can be defined for accelerating observers without issues, while others disagree and highlight potential problems related to quantum fluctuations.
  • One participant emphasizes that the assumption of infinite mass in detector models leads to complications when gravity is considered, as it could imply a collapse into a black hole.
  • Another participant challenges the notion that fluctuating foliations are a novel idea, suggesting that the classical limit of quantum mechanics should be established without resorting to problematic limits.
  • References to the histories approach by Isham, Linden, and Savvidou are made, indicating some overlap with the current discussion but uncertainty about its status in relation to standard canonical QFT.
  • There is a general acknowledgment that a quantum foliation is not part of standard canonical QFT, but some participants suggest that path integrals may simplify these considerations.
Participants express differing views on the treatment of foliations in quantum gravity and the implications of accelerating observers. There is no consensus on whether the issues raised regarding quantum fluctuations and foliations are problematic or if they can be reconciled within existing frameworks.
Participants note that the discussion involves complex assumptions about the nature of time, mass, and the behavior of observers in quantum mechanics, which may not be fully resolved within the current dialogue.
This discussion may be of interest to researchers and students in theoretical physics, particularly those focused on quantum field theory, quantum gravity, and the implications of acceleration in quantum mechanics.
Thomas Larsson
In order not to further irritate Marcus, let us move this off-topic discussion from the Rovelli thread.
Careful said:
** In conventional QM, time just marches on independent of what happens. Time must operationally be defined by ticks on the observer's clock, and thus the observer does not accelerate.**
? There is no problem whatsoever in defining QFT with respect to (non-uniformly) accelerating observers (and bending the foliation according to local eigentime - as long as one does not encounter focal points).
Whether the foliation is bent or not has nothing to do with my argument. By talking about a foliation, you are making a hidden assumption about classical observers. However, since the observer's trajectory is a quantum variable, it can only be specified if we leave the observer's momentum completely undetermined. Or vice versa. This means that the foliation itself is subject to quantum fluctuations, which is the essential physical novelty.
Careful said:
** This is no problem we observe an electric phenomenon, say. Then F = ma = qE, where q is the observer's charge and E the electric field generated by the system. That q and E are non-zero and a = 0 is OK, since m = infinity is a good approximation to reality. **
? The m in the Newton formula is the physical mass and not the bare mass, for an electron that is still the very tiny number of 10^{-30} kilo at least when it moves smaller than c wrt an inertial observer. You can find such information in Eric Poisson, ``An introduction to the Lorentz Dirac equation´´ gr-qc/9912045 where such understanding is offered at a classical level.
In typical accelerator experiments, the detectors weigh several tonnes, and measurements are related to the detector's rest frame. The assumption that such a detector does not recoil at all is an excellent approximation, which is implicit in the assumption that the detector follows a sharp, classical trajectory. However, it is an approximation, which amounts to replacing several tonnes by infinity. When gravity is turned on, this becomes a problem, because an infinite mass will immediately collapse into a black hole. This is an essential difference between gravity and other interactions.
Whether the foliation is bent or not has nothing to do with my argument. By talking about a foliation, you are making a hidden assumption about classical observers. However, since the observer's trajectory is a quantum variable, it can only be specified if we leave the observer's momentum completely undetermined. Or vice versa. This means that the foliation itself is subject to quantum fluctuations, which is the essential physical novelty. **
Don't you think I realize that ?? Moreover, I still do not agree that it is some kind of foliation which is subject to fluctuations in your framework (fix the ontology of your t sensibly). By referring to the standard QFT result I merely asserted that you should obtain the latter result for ``macroscopic´´ observers in your framework. And for that you do not have to take the sick limit M -> infinity which indeed causes trouble for gravity. You might try to establish such correspondence at the statistical level, by considering the deterministic evolution of expectation values of the worldline operators (a la Ehrenfest) exactly like some people try to take the ``classical limit´´ of quantum mechanics (it came as a surprise to me that you did not realize that). This answers immediatly the rest of your message. Frankly, the idea of fluctuating foliations is not a novetly either, your work at the Hamiltonian level (again fix the ontology of t) however is (to my knowledge). That is why I said that the paper interesting even if it turns out to be entirely wrong.
But you also wrote
"? There is no problem whatsoever in defining QFT with respect to (non-uniformly) accelerating observers (and bending the foliation according to local eigentime - as long as one does not encounter focal points)."
Thus you seem to be saying that there is no problem whatsoever in defining QFT over a foliation which itself is subject to quantum fluctuations. This statement may raise some eyebrows. At least I disagree.
It is of course widely expected that the foliation is quantized on quantum gravity, but I am only aware of one more suggestion how to implement this technically, namely the histories approach of Isham, Linden and in particular Savvidou, see e.g. http://www.arxiv.org/abs/quant-ph/0110161 . There is some overlap between my approach and theirs, but I am not sure about the exact status of their work. Anyway, a quantum foliation is certainly *not* part of standard canonical QFT.
I repeat myself : all I said is that there is no problem in defining QFT over a foliation corresponding to accelerated observers. OBVIOUSLY, I consider the observer classical here, and I alluded already to the unavoidable problem which raises in quantum theory for the foliation - and that are the focal points. Moreover, I implied by this that any theory which treats the foliation as quantum obviously needs to incorporate the possibility for acceleration.
** namely the histories approach of Isham, Linden and in particular Savvidou, see e.g. http://www.arxiv.org/abs/quant-ph/0110161 . There is some overlap between my approach and theirs, but I am not sure about the exact status of their work. **
I know that approach.
**Anyway, a quantum foliation is certainly *not* part of standard canonical QFT. **
right, but in path integrals that all becomes much easier as I said in the beginning. This conversation is finished.
a courteous good morning to you gentlemen (pacific time)
fascinating discussion
glad you made a thread for it
  • · Replies 72 ·
12K
  • · Replies 0 ·
  • · Replies 0 ·
