Why Are Magnesium and Beryllium Not Chemically Inactive?
  • Context: High School
  • Thread starter Thread starter ghallya
Magnesium (Mg) and Beryllium (Be) are not chemically inactive despite having closed subshells due to the requirement of a valence shell octet for stability. Their reactivity is attributed to being only two electrons away from achieving this octet, which overshadows the stabilization provided by filled subshells. Ionization energies (IE) demonstrate this phenomenon, with Be exhibiting an IE of 899.5 kJ/mol, higher than Boron (B) at 800.6 kJ/mol, and Mg at 737.7 kJ/mol, surpassing Aluminum (Al) at 577.5 kJ/mol. This indicates that the filled subshells contribute to increased stability, making it more difficult to remove valence electrons from Be and Mg.
  • Understanding of atomic structure and electron configurations
  • Familiarity with periodic trends in ionization energy
  • Knowledge of valence shell octet rule
  • Basic concepts of electron affinity
  • Research the concept of valence shell octet and its implications in chemical reactivity
  • Study periodic trends in ionization energies across different groups in the periodic table
  • Explore the relationship between electron configurations and chemical properties
  • Investigate the concept of electron affinity and its periodic trends
Chemistry students, educators, and professionals interested in understanding the reactivity of alkaline earth metals and the principles of atomic stability.
ghallya
Hi all
I was woundering , and I searched for a convincing answer but
I didnt find any , so i hope i will find it here :)
Both Be and Mg (ofcourse othe examples apply ) have closed subshells
, why are they not chemically inactive (inert) ?:confused:
Having closed subshells is not a condition for chemical inertness. The condition that maximizes stability (minimizes reactivity) is a valence shell octet (or a duet in the case of He).
However, having fully filled (and even half-filled) subshells does contribute to some increased stability. The fact that Be amd Mg are inherently so reactive (being only 2 electrons removed from an octet/duet) makes it a little hard to notice this small stabilization due to the filled subshell. However, careful measurements of ionization energies (and even electron affinities) clearly illustrate this stabilization.
Compare the 1st ionization energies of Be and B, and those of Mg and Al. The periodic trend is for the IE to increase as you go down the period. However, Be has a higher IE (899.5 kJ/mol) than B (800.6 kJ/mol) and Mg has a much higher IE (737.7 kJ/mol) than Al (577.5 kJ/mol). This is telling us that it's harder to pull out a valence electron from Be and Mg than from B and Al. This is a direct result of the extra stabilization from the filled subshells.
Note 1 : A similar disruption of the periodic trend in IEs is observed when you go from the N group (which has a half filled p subshell) to the O group.
Note 2 : Although less convincing (because the periodic trends are not as clear as with IEs), the effect of the stabilization is also seen in the electron affinities.
thank you very much , I really appreciate your help :)
  • · Replies 19 ·
11K
  • · Replies 21 ·
  • · Replies 22 ·
