What is the maximum speed of the ejected electrons? good times
The discussion revolves around the maximum speed of ejected electrons when light of a specific wavelength interacts with a metal, given its work function. Participants are exploring the relationship between stopping potential, kinetic energy, and the energy of incident photons.
  • Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the use of the stopping potential and its relationship to the kinetic energy of ejected electrons. There are attempts to derive the maximum speed using energy equations, but confusion arises regarding the proper use of units and the relationships between energy, voltage, and charge.
Some participants have provided guidance on the conservation of energy principle and the correct interpretation of the stopping potential. There is an ongoing exploration of how to properly relate the stopping potential to the kinetic energy of the electrons, with no explicit consensus reached yet.
There appears to be confusion regarding the conversion of energy units and the application of formulas related to voltage and kinetic energy. Participants are questioning the assumptions made in their calculations and the definitions of the terms used.
mr_coffee
Hello everyone, I'm alittle confused on why this isn't right.
THe problem asks:
They give you the following:
With the help of others i found:
If the work function for a certain metal is 1.5 eV, what is its stopping potential for electrons ejected from the metal when light of wavelength 337 nm shines on the metal?
2.19 V
Andrew Mason said it best:
The stopping potential is the potential (energy / unit charge) measured in volts (joules/coulomb) that must be applied to stop the electrons from being ejected from the surface when the light is shone on it.
If the energy of the incident photon is greater than the work required to remove the electron from the surface plus the applied (-) potential, electrons will leave the surface with some kinetic energy. The stopping potential is the applied potential that makes this KE = 0.
So the stopping potential is given by:
[tex]q_eV_s = E_{photon} - q_e\phi[/tex]
[tex]V_s = h\nu/q_e - \phi[/tex]
where [itex]V_s[/itex] is the stopping potential and [itex]\phi[/itex] is the work function (Joules/coulomb)./QUOTE]
So i figured this formula would work,
Stopping Potential = 2.19 V
.5*mv^2 = Stopping Potential;
solve for V to find the speed.
V = sqrt(StoppingPotential/(.5*m));
V = 2.5E15 m/s
but it was wrong. ANy ideas what I'm missing? Thanks!
eV is a measure of energy, not voltage, so in your equation [tex]V_s = h\nu/q_e - \phi[/tex] you are equating potential to potential plus energy.
Also you set voltage equal to kinetic energy. Again, voltage is energy/charge.
Your right, my units don't work out at all. I end up getting volts/kg hm...
I don't see how this is going to work out, are you saying I should convert my 2.9 V into somthing else?
You have to realize what is going on.
Once the electron has been shot out, it takes a potential of 2.19 Joules/coulomb(if you did your calculations correctly) to stop them.
If it takes 2.19 Joules/Coulomb to stop the electron, what does that tell you about its initial kinetic energy?
I guess the key thing to realize is that all this is is conservation of energy. You don't need to memorize any formulas if you just understand the situation and write a conservation of energy statement for it.
In the first case you have the energy of the photon converted into the work function energy plus the energy of the electron. Then you have the energy of the electron converted into electric potential (qV)
Oooo! i got you so it should be:
.5*mv^2 = (charge of an electron)(2.19 J/C)?
  • · Replies 22 ·
