What Motherboard Is Good For that CPU?
  • Thread starter Thread starter Omid
    cpu
The discussion revolves around finding compatible motherboards for specific CPUs. Participants explore methods and resources for determining motherboard compatibility without extensive research.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant expresses a desire for a straightforward way to find compatible motherboards for a given CPU, mentioning the time-consuming nature of checking manufacturer websites.
  • Another participant suggests identifying the CPU socket type as a method to determine compatible motherboards and asks for the specific CPU in question.
  • A third participant recommends a specific website, www.motherboards.org, and describes a process involving an ActiveX installation to find motherboard compatibility.
  • A later reply expresses enthusiasm for the suggested URL, indicating it may be helpful.
Participants generally agree on the importance of knowing the CPU socket type for compatibility but do not reach a consensus on a single best method or resource.
Some suggestions depend on specific tools or websites, and the effectiveness of these methods may vary based on user experience and system configurations.
Individuals looking to build or upgrade a computer system, particularly those unfamiliar with motherboard compatibility issues.
Omid
Hi there,
I need a good and handy way to findout, without too much pain, which motherboard is compatible with a certaini CPU. I usually check the motherboard manufacturer websites for this, but it takes me a lot of time.
Do you know a website for that porpous? A place where you give them a CPU type and it suggests some good motherboards for it?
Thanks
Computer science news on Phys.org
If you know the CPU you can find out what type of socket it is and then based on that you know which motheboards can accept the CPU.
Which CPU do you have in mind?
Here's something you can try:
Go to www.motherboards.org
Scroll down while looking at the left side of your screen. You will see an ad feature titled "Upgrade Your Processor" from PowerLeap.
Click on that and allow the ActiveX to install.
Your screen may go weird for about 30 seconds(mine did) Patience!
Then a new screen appears and follow the instructions on the right.
Note that this utility only works with respect to a motherboard actually being used to initiate this query.
yo that url is amazing
  • · Replies 40 ·
  • · Replies 30 ·
