What is the force propelling us through time?
  • Context: Graduate
  • Thread starter Thread starter Binary Star
    Force Time
The discussion revolves around the concept of time as a dimension and whether a force is required to propel objects through it. Participants explore various perspectives on the nature of time, its relationship with gravity, and the implications of viewing time as a physical dimension versus an abstraction. The scope includes theoretical considerations and philosophical implications.
  • Some participants propose that if time is a dimension, a force must be acting to pull objects through it, potentially proportional to mass.
  • Others argue that no force is needed to maintain constant motion through time, drawing parallels to Newton's first law of motion.
  • A later reply suggests that while an initial force may have set motion in time (e.g., the Big Bang), ongoing motion does not require continuous force.
  • One participant humorously suggests "peanut butter" as a force, indicating a light-hearted approach to the question.
  • Another perspective posits that the concept of traveling through time is an abstraction based on observing physical changes in systems, influenced by gravitational forces.
  • Some participants express uncertainty about the nature of time, suggesting it might be better viewed as a property rather than a dimension.
  • There is a discussion on the relationship between gravity and time, with some asserting that gravity and time may share a common origin, while others maintain they are distinct concepts.
  • One participant emphasizes that general relativity (GR) and special relativity (SR) treat the relationship between mass, time, and gravity differently, leading to further debate on their implications.
  • Concerns are raised about the need for new theories to align with established facts, particularly regarding GR and SR.
Participants express a range of views, with no consensus reached on whether a force is necessary to move through time or the fundamental nature of time itself. Multiple competing perspectives remain, particularly regarding the relationship between gravity and time.
Some arguments depend on specific definitions of time and gravity, and there are unresolved mathematical and conceptual steps in the discussion. The varying interpretations of time as a dimension versus a property contribute to the complexity of the debate.
Binary Star
I'm just wondering, since we are traveling through time constantly. If time is a dimension, then should be some sort of force pulling everything through time, right? I guess it would have to be proportional to mass, since particles with zero mass do not travel through time at all.
If time is a physical dimension, I'm not saying it is or is not, then no force would be required for you to move through it. A massive object's motion in space will remain constant unless an outside force acts on it. A force is not required to keep an object in motion. If we have a constant motion in time, then a force is not necessary to maintain that motion. That is if time can be viewed as a physical dimension like space.
If time is just an abstraction, however, then the need of a force to propel us through time is not necessary.
Added later:
Of course, an initial force would be required to set our motion in the first place. If I had to guess, I would say the big bang would have provided that force. That's just a guess. Deep theories of cosmology are pretty much beyond my understanding.
"What is the force propelling us through time?"
Peanut butter.
We are not all traveling through time constantly. It may appear to be the case since we are moving at approximately the same velocities through the universe and perturbed by approximately the same amounts of gravity by surrounding bodies. So, more or less, we (as in, slow-moving earthlings) are traveling through time similarly. But, the notion of traveling “through” time is based entirely on the concept of time itself being a dimension that can be moved through in the first place. While it is a pleasant fantasy to hold on to this idea, which allows for the forward (or positive) and backward (or negative) movement through time, it should be viewed as the ability to observe physical differences in systems: a simple abstraction. The conversion and/or transfer of energy are at the very foundation of observing such physical differences in systems. Gravity waves emitted from all massive objects affect how slowly (or less slowly) these transformation processes take place, and consequentially when changes in a system can be measured. Varying gravitational forces at different points in space can therefore create different rates of time for surrounding massive objects.
The simple answer is that the force of gravity in contention with the energy supplied by the big bang allows us to observe the changes in systems and thus abstract the concept of time.
or more simply...we don't really know. Time is perhaps better viewed as a property rather than a dimension. Always increaseing, except at different rates depending on the gravitational force acting on it (there are several logical issues there that I'm aware of, just pondering not proposin here, so please don't attack me for them).
A "force" applied would mean that we would be accelerating through time. As long as the "time velocity" is constant no force is needed.
Remember F=ma
Remember F=ma
Except that under general relativity time velocity IS NOT constant, and it does not follow F=ma, since in GR there is also no gravitational "force" per se.
Originally posted by franznietzsche
...Time is perhaps better viewed as a property rather than a dimension...
Yes! That is a great way to look at it.
Remember F=ma
"Force" was meant not only in the sense of a fundamental force, but to frame the answer in a similar form to which the question was asked.
I see your uncommon mind, Binary Star. You have the thin feel of interrelations existing in the nature, though the real picture is looked a little differently. You are not surprised with the fact, what all events in the universe are synchronized, i.e. time is propagates without delay? You are not surprised with the fact, what even by elementary calculations a force of gravity would not have any delay in propagation otherwise it will not allow one object to keep in an orbit another object (the Sun and the Earth, for example) i.e. gravity force is propagated without delay too. It means, that these two phenomena having identical property have the general origin too. How it is possible to do the association of two such "absolutely different" phenomena? Here I’ll make a pause to miss a stream of the indignant retorts.
To be continued.
I am slightly surprised with absence of objections, nevertheless, I continue further.
How it is possible to present gravity and time as two essence having the general origin? What a secret? May be it is one essence actually? Let's compare their action. Gravity is directed on reduction of intervals between the objects having rest mass. It is shown as the action of attraction force between objects.
Except it a gravity operates on object. This action is directed on reduction of object’s energy (frequency of vibrations) and shown in emission of photons. If regeneration due to absorption of other photons is absent, the object "grows old", degrades i.e. loses mass and then stops the existence.
It is possible to say “ the object has died ”. This a picture precisely corresponds how the time works. Our clocks are the counters of seconds (hours) and does works on accumulation. The people have decided so, because it is convenient and logical. The nature uses the clock , tick of which reduces initial energy = time cycle = frequency of vibrations = a data set of an object . An interval between objects it is the object too. Each an object lives in its own time cycle from a birth to death. Clock of the nature ticks with a frequency 1/Planck Time. It is the maximum frequency existing in universe. Action of these subtracting pulses (time = gravity) is simultaneously for all objects of universe .
SR deals with Mass and Time in the absence of Gravity
If Gravity = Time then SR would have to account for Gravity when dealing with Time. It doesn't, but GR does.
Your statement may be close for GR, but not SR and since everything in our Universe appears to be in motion, it doesn't hold up at all.
Time has a relationship to Gravity, but Gravity does not have a relationship to Time.
I have own opinion on the device of universe.
For all the wonderful new theories that individuals come up with, there is one underlying criteria that needs to be common to all of them, they must fit the facts.
GR has been proven numerous times, as has SR.
I personally don't agree with the reasoning behind GR and SR as far as SpaceTime is concerned, but I do agree with the results.
As to your device of the Universe, if it's to be taken seriously it will need to fit the facts, albeit using some different reasoning.
but by definition crackpots refuse to recognize reality, their theories need only match their own platonic constructs to please them. /rant
Yeah question old theories is one thing, reinventing reailty is another.
Good attitude - you accept that it works but are looking for a better explanation for why. That means any idea you come up with will be consistent with observed reality - a rarity in the TD forum.
Thanks for that Russ.
I believe the answer will come in the form of a Rosetta Stone.
One small discovery that will make sense of everything.
And it proberbly won't be found in the debrit of an particle accelerator. It may be right in front of our faces.
Can't see the wood for the trees.
Guys,
Are you sure on GR, SR or other existing theory answers a question that the time and gravity are?
If you are informed on it, then I would like to hear definition of these phenomena. Or, may be, you have own theories? Then we’ll have a base for comparison.
I have always had a problem with the concept of SpaceTime.
I feel it is on a par with Creationists in that it requires faith.
SpaceTime is considered to be a 4 dimensional manifold which will not be flat if gravity is present.
Alternatively, space is a 3 dimensional medium that undergoes compression due to gravity. Time is relative to the amount of compression.
Using Occam's Razor, I know which one I would pick.
Except the creationists can't predict the perihelion shift of mercury. It doesn't really require faith. It doesn't answer the question what time is, but it does answer the question of what gravity is (referring to GR), a warping of space and time, not just space. And in terms of its predictions, it is very veryy accurate. Its assertions about the nature of space and gravity might be incorrect, but its mathematics are very close to the real thing. So it is not really a fair comparison.
Fair comment. I used Creationism (is that a real word) as an example of Faith, not as an exampe of how the Universe began. Although some will argue the point - not here please.
SpaceTime is a mathematical abstraction.
Cause and effect.
The effect of Gravity has been theorised, formulated and proven - with a great degree of accuracy.
The cause, however, is still open to discussion.
In finding the cause, the definition of SpaceTime and why it appears to be warped will become clearer.
So this foggy definitions we’ll take as a base.
Sorry, but it’ll be processed until you will not get acquainted and agree with real theory.
So. SpaceTime is [x,y,z,t].
Are you agree, what each dimension should react to any influence equally? If any action reduces the Space that simultaneously it should reduce the Time.
If one of four dimensions has another properties it has no any relation to an others three.
Here you exclude Time from structure of four dimensions into the separate essence and assert to it another properties (see above).
An exceptable explanation of the Universe is that it is 3+1 dimensions. The +1 being time.
It is not one of the major dimensions because it is a virtual dimension.
3+1 dimensions works for me.
Originally posted in another topic
Its simply a fact of life that there is a maximum speed in the universe. The geometrical structure of spacetime is a consequence of this.
SpaceTime exists as a consequence of there being a constant speed of light, yet the speed of light is determined by the nature of SpaceTime.
Under SpaceTime, there is no explanation of why light has a constant speed, and why this speed is the maximum speed in the Universe, except that without it SpaceTime wouldn't work.
I have no doubt that the maths works, but the logic as to why leaves a lot to be desired.
Time is a measure of motion, specifically, the entity against context. The entity is the hand of the clock and the context is the face. Context isn't absolute, so it constitutes an opposite direction of time. From the perspective of the hand, the face is moving in the opposite direction. As everything is context to everything else, then all motion is in equilibrium.
Time is a measure of sequence and duration. Velocity is a measure of motion.
Sequence can be omnidirectional, but it is always incremental, hence time marches on.
The time of the hands of a clock is slower than that of the clockface because the hands have a relative velocity with respect to the clockface - albeit very small.
Pages (3): « 1 2 [3] Go to first unread post _ Last Thread _ Next Thread
Author
_AWolf,
"Time is a measure of sequence and duration."
The sequence and duration is against a scale, such as the face of the clock.
"Velocity is a measure of motion."
We can only measure the velocity of any object relative to background context.
"Sequence can be omnidirectional, but it is always incremental, hence time marches on."
The scale must be incremental.
"The time of the hands of a clock is slower than that of the clockface because the hands have a relative velocity with respect to the clockface - albeit very small."
Are you agreeing that the face is moving opposite the hand(s), or observing the object of the clock is a moving object in some larger context?
Context is not an absolute. It consists of other objects. If your frame of reference is riding in a car, then relative to you, it is the road that is moving under the car. Consider objects closer in size; Does the moon revolve around the earth, or do they both revolve around a common center of gravity?
There are two frames of reference for Time. One is the local frame of reference where time is measured by you. Any velocities are relative to your velocity, and subsequently time is relative to your time.
The other frame of reference is Universal Standard Time (UST).
UST is a frame of reference which is not acted on by gravity and has no velocity.
Seeing as how we are traveling through the cosmos at approxiamtely 1% the speed of light and contained within a Gravity Well that is our planet/solar system/galaxy, our own local frame of reference is about 99.99% UST.
From this you can work out our scale.
The example of the clock face provides a reference scale against the movements of the hands. If all the numbers on the clock face were in reverse, it does not effect the movements of the hands, or their ability to mark off each second as it passes. The scale of the numbers on the clock face is for our convenience only.
Time is a measure of sequence and duration - Sequence can be omnidirectional, but it is always incremental
Having taken one step in a sequence, no matter whether you change direction or keep going straight on, you must always take the next step, hence it is sequence that is incremental.
AWolf,
UST is still calibrated in terms of seconds, minutes, hours, days, months, years, etc. which originated with reference to the Earth's relation to it's most prominent celestial neighbor, ie. the entity in relation to context. That UST is no longer actually calibrated in terms of this relationship, but to more accurate scales, is simply due to this not being precise enough measurement for modern convenience.
Exactly. Context isn't absolute.
Right. Motion doesn't necessarily have a reference frame. Order is determined by perspective.
Time is really the fourth dimension of our Universe, but not in the sense we are used to think of.
In a theory of mine (Universal Contraction Theory) Space is a 3-dimensional frame because of the spherical symmetry of an orthogonal movement in a fourth dimension. This dimension is the direction of the "clock" of the Universe-machine therefore it cannot be perceived itself as a spatial dimension. Any projection of the time axis on space frame is not a 3-dimensional object. Nevertheless the topological stability of space must be related to something synchronic so that space-time frame can occur.
Consider each point of matter (typically a proton) as a pulsating 3-dimensional whirlpool in which all the void space is attracted at light speed.
The frequency of contraction itself, when syncronized with other points of contraction provides the space frame and the necessary clock to allow events to occur.
Paglren,
I guess you would have to expand on this for me to grasp it enough to give a specific reply.
I do have a problem with defining space as three dimensional, though. The assumption seems to be that it simply delineates volume, but it is in fact a coordinate system and there are no absolute coordinate systems, so while a map of space might be three dimensional, the actual territory of it would be infinitely dimensional.
  • · Replies 95 ·
  • · Replies 69 ·
  • · Replies 27 ·
  • · Replies 21 ·
  • · Replies 20 ·
  • · Replies 25 ·
