| Thread Closed |
Solids of Revolution |
Share Thread | Thread Tools |
| Apr22-06, 05:45 PM | #1 |
Find the volume formed by rotating the area contained by y=sqrt(6x+4), the y-axis and the line y=2x about the y-axis. Set up, but do not evaluate the integral.
First I graphed it, then did the "washer" method of finding the area of the circle formed, and found that the radius is (y/2-sqrt[(y^2-4)/6]. Is this right? I then found the height, which would be sqrt(y/2-sqrt[(y^2-4)/6], wouldn't it? Then the answer is: the integral from 0 to 4 of pi times the radius squared, times the height times dy. I don't have an answer key, but could someone help me with this? |
| Apr23-06, 05:26 AM | #2 |
Do you have to use the washer method? I think it would be easier to use cylindrical shells.
Secondly, there is no one "radius." The volume for a washer is given by, [tex]V = \pi[(\mbox{outer radius})^2 - (\mbox{inner radius})^2)] * (\mbox{thickness}) [/tex] You want to find functions for the "outer radius" and the "inner radius." (Be careful, these might not be the same over your whole interval of integration) [tex]V = \pi[(\mbox{outer radius})^2 - (\mbox{inner radius})^2)] * (\mbox{thickness}) [/tex] I think it would help if you went over some examples from your text book. Here is an example of the washer method when rotated about the x-axis. Go to example 5 under heading "washers" washer example your book should have a better example (hopefully) |
| Apr23-06, 08:45 AM | #3 |
The volume you are looking for is [tex]\pi\int_0^2\frac{y^2}{4}dy+ \pi\int_2^4(\frac{y^2}{4}-\frac{(y^2-4)^2}{36}dy[/tex] |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Solids of Revolution
| Mean Value Theorem to calculate solids of revolution??? | Calculus | 2 | ||
| Advice on volume of solids NOT of revolution? | Calculus & Beyond Homework | 6 | ||
| matlab & solids of revolution?? | Math & Science Software | 2 | ||
| Solids of revolution | Calculus | 5 | ||
