Formation of compounds (Organic Chemistry)
The discussion focuses on the formation of esters, specifically butyl propanoate and propyl methanoate, through dehydration reactions. The balanced equations for these reactions are derived from the general esterification formula: R-COOH + R'OH → R-COOR' + H2O. The reactants identified are butanol and propionic acid for butyl propanoate, and propanol and methanoic acid for propyl methanoate. An acid catalyst, such as sulfuric acid, is necessary to facilitate the reaction.
  • Understanding of esterification reactions
  • Knowledge of organic compounds, specifically alcohols and carboxylic acids
  • Familiarity with balanced chemical equations
  • Basic concepts of dehydration synthesis
  • Study the mechanism of esterification reactions in detail
  • Learn about the role of acid catalysts in organic reactions
  • Explore the properties and applications of esters in organic chemistry
  • Investigate the differences between various types of organic reactions, such as elimination and substitution
Chemistry students, organic chemists, and anyone interested in understanding the synthesis of organic compounds, particularly esters.
ScrubsFan
Write balanced equations to show the formation of each of the following compounds. Name the reactants in each case, and show clearly the removal of the water molecule.
a) butyl propanoate
b) propyl methanoate
Im not exactly sure how to answer this question... below are pics of the structural formulas.
a) butyl propanoate - CH3CH2COOCH2CH2CH2CH3
b) propyl methanoate - HCOOCH2CH2CH3
I know the reaction will be a deydration (Elimination) seeing as the water molecule is removed. I am lost on where to go from here though; and even if what I have done so far is right.
Both of those compounds are esters. They are derived from an alcohol and a carboxyllic acid, and water is, as you noticed, removed.
The general reaction for forming esters is: R-COOH + R'OH --> R-COOR' + H2O
a) butanol + propionic acid
b) propanol + methanoic acid
You also generally need an acid catalyst like sulfuric acid to drive this reaction to completion.
  • · Replies 21 ·
13K
