Where Can I Find a Vacuum Tube for Household Object Experiments?
The discussion revolves around finding or creating a vacuum tube suitable for conducting experiments with household objects, particularly focusing on the effects of a vacuum on items like ice. Participants explore different options for vacuum chambers and share ideas for constructing them.
  • One participant seeks a vacuum tube with a 3-inch diameter for experiments on household objects.
  • Another suggests using a bell jar as a more accessible option for creating a vacuum.
  • A participant humorously corrects a previous post regarding the size of the vacuum tube, clarifying it should be 3 inches, not 3 feet.
  • There is a discussion about the cost of vacuum tubes, with one participant expressing a willingness to spend money for a quality item reminiscent of a physics demonstration from their past.
  • Another participant proposes an alternative approach using HDMW plastic to construct a vacuum chamber, emphasizing durability and cost-effectiveness.
  • A unique design idea is shared involving a glass rod coated with liquid rubber to create a vacuum effect upon breaking, although its practicality is not assessed.
Participants present multiple competing views on the best approach to obtaining or creating a vacuum chamber, with no consensus reached on a single solution.
Some suggestions depend on specific materials and construction techniques, which may not be universally applicable. The feasibility of proposed designs remains unverified.
Individuals interested in experimental physics, DIY projects, or those looking to explore the effects of vacuum on various materials may find this discussion relevant.
Tweek
in which I could fit about a 3" diameter object in. I have searched and searched all over the net and I can't find any. I would like to purchase a vacuum tube so that I could do several experiments on what happens to household objects in a vaccum. I would like to see how ice changes in it among many other objects.
You need a bell jar. Try that as a key word in you search.
Edit:
3'! That is a pretty good sized bell jar. Do this compute the surface area of something big enough to hold that, then multiply by 14.7 lb/in2.
I'm sorry I wrote this late at night. I meant 3 inches haha
That would be huge if it was 3 feet
Ok, that's better. 3" Is easy. even so I don' think they give them away!
I'm prepared to spend some money on it. My physics teacher from long ago had one. I want one just like his. It had a clear tube so you could watch the penny and feather inside of it fall at the same speed.
Youd be better off using a HDMW plastic like kevlar get a pipe ( 4*5~6" or so )and a base and cover ( normally a plexi supplier can machine these to spec. You dead end the bottom and put a lid on with .say a rubber gasket and two draw latches, slap a vacuum gauge in there and a suction port and viola' a vacuum chamber you can throw out of a speeding car that won't break and one that will cost considerably less then a Pyrex object.
edit sp
You could also take a 1-inch diameter by 1-foot glass rod, liberally coat it with liquid rubber all around, 1/4-inch on all sides, but even thicker at the center.
Allow to cure.
Strike the rod at the center, causing the rod to break at that point.
Now, try to pull the two halves apart.
One hell of a vacuum.
O.K. it's my design, but a neat idea if carried forward.
  • · Replies 17 ·
  • · Replies 21 ·
