Thread Closed
transformer voltage
Share Thread
Apr24-06, 08:16 PM   #1
transformer voltage
I'm using a 460VAC/230VAC single phase transformer. My customer insists wanting to have 440VAC/220VAC one instead. The ratio between the two transformers are the same. How different are the two? Are they essentially the same ?
Thank you,
PhysOrg.com engineering news on PhysOrg.com
>> Multiview 3-D photography made simple
>> Giant 3-D printed bugs shed light on insect anatomy
>> A microphone that listens with light
Apr24-06, 08:59 PM   #2
Mentor
Both will output the same voltage, which will be determined by the actual voltage input. I'm guessing you are in Europe? The nomial voltage can be either depending on the country (apparently, most are switching to the 460/230 standard). In the US, nominal is 480/240/120.
The two transformers may have different kVa ratings due to the voltage difference... but if you ratio them to the voltage, I bet you'll find they are exactly the same.
Thread Closed
Similar discussions for: transformer voltage
Thread Forum Replies
S4 helix of voltage-gated channels is the voltage sensor of the channel Biology 1
CIRCUITS: Current Controlled Voltage source, Indep. Voltage source, Four resistors... Introductory Physics Homework 1
Transformer Introductory Physics Homework 2
Where can i get voltage transformer Electrical Engineering 1
COMMON MODE VOLTAGE? Can it be a DC voltage? Electrical Engineering 3
