Is a Methane-Molecule-Like Solar System Stable?
  • Context: Graduate
  • Thread starter Thread starter neutrino
    Stable System
The discussion revolves around the stability of a hypothetical solar system modeled after a methane molecule, with a central star analogous to carbon and planets representing hydrogen atoms. Participants explore the parameters necessary for stability, including mass, orbital radius, and gravitational conditions for human survival. The conversation includes theoretical considerations and mathematical modeling related to gravitational interactions within such a system.
  • One participant suggests that for the system to be stable, planets must have equal mass and orbital periods to avoid perturbations, or they must occupy separate orbits.
  • Another participant notes that the hydrogen atoms in methane are not planar, which complicates the idea of all planets moving in the same direction.
  • A participant mentions a previous solution involving 64 planets in a "buckeyball" configuration, indicating potential for complex orbital arrangements.
  • Concerns are raised about the difficulty of calculating interactions in gravitationally bound systems, particularly with three-body problems.
  • One participant provides a detailed Hamiltonian formulation for the system, discussing the stability conditions derived from the characteristic polynomial and suggesting that the system may be marginally stable with a central mass.
  • Another participant questions the stability of the system without a central mass, indicating that it may not be stable for four bodies.
  • Numerical simulations of systems with a high number of bodies and no central mass are mentioned, suggesting interesting behaviors such as linear instability with limit cycle oscillations.
Participants express differing views on the stability conditions of the proposed system, with some agreeing on the necessity of equal mass and periods for stability, while others raise concerns about the implications of non-planar motion and the role of a central mass. The discussion remains unresolved with multiple competing perspectives on the stability of the system.
The discussion highlights limitations in calculating gravitational interactions and the assumptions underlying the models proposed. There are unresolved mathematical steps and dependencies on specific definitions of stability and orbital configurations.
neutrino
I just came across a question in another forum regarding the stability of a rather strange system. A huge methane-molecule-like system with the parent star in the place of carbon, and the planets in the place of H atoms (It's actually for a sci-fi story). If the planets moved in the same direction (that's what the OP said), what are the parameters in terms of mass, radius of orbit etc for this system to be stable. Also the planets should have a g-value so that humans could survive.
I'm guessing that if it started out as a normal system, i.e. with the planets in a plane, then it should have had a violent past for the planets to go elsewhere. I also think that collision(s) should have been fine-tuned to form such a system.
Astronomy news on Phys.org
The hydrogen atoms in methane are not planar, so their angular momentum vectors would not be the same, i.e. they cannot be moving in the same direction or planar orbit.
To be 'stable' with four planets which are equidistant from the central star, the planets would have to be the same mass and period in order not to have at least one over take another. Otherwise the planets have to be in separate orbits. The system would be stable if the masses and periods were such that the planets did not perturb each other.
I've lost the link, but somebody has solved the problem of 64 planets in mutual attaction orbiting to form a "buckeyball" configuration. He has an animation of it too.
Yes, the masses must be equal given the symmetry of the system at any instant. If we separate the planets in two pairs, the members of a pair sharing an orbit with the same period, will this make the planets move without perturbing the others? Of course, the main question is how would one determine the numbers.
That would be one amazing system to watch! Please do post the link if you come across it.
I have no clue how you would go about calculating interactions. Even 3 body solutions are difficult to approximate in gravitationally bound systems.
I did a semi-insane amount of work on this and related problems a while back.
If you take the Hamiltonian of this system, H
H = 1/2*px[1]^2+1/2*py[1]^2+w*(px[1]*y[1]-py[1]*x[1])+
1/2*px[2]^2+1/2*py[2]^2+w*(px[2]*y[2]-py[2]*x[2])+
1/2*px[3]^2+1/2*py[3]^2+w*(px[3]*y[3]-py[3]*x[3])+
1/2*px[4]^2+1/2*py[4]^2+w*(px[4]*y[4]-py[4]*x[4])
-1/((x[1]^2-2*x[1]*x[2]+x[2]^2+y[1]^2-2*y[1]*y[2]+y[2]^2)^(1/2))
-1/((x[1]^2-2*x[1]*x[3]+x[3]^2+y[1]^2-2*y[1]*y[3]+y[3]^2)^(1/2))
-1/((x[1]^2-2*x[1]*x[4]+x[4]^2+y[1]^2-2*y[1]*y[4]+y[4]^2)^(1/2))
-1/((x[2]^2-2*x[2]*x[3]+x[3]^2+y[2]^2-2*y[2]*y[3]+y[3]^2)^(1/2))
-1/((x[2]^2-2*x[2]*x[4]+x[4]^2+y[2]^2-2*y[2]*y[4]+y[4]^2)^(1/2))
-1/((x[3]^2-2*x[3]*x[4]+x[4]^2+y[3]^2-2*y[3]*y[4]+y[4]^2)^(1/2))
-M/(x[1]^2+y[1]^2)^(1/2)-M/(x[2]^2+y[2]^2)^(1/2)
-M/(x[3]^2+y[3]^2)^(1/2)-M/(x[4]^2+y[4]^2)^(1/2)where M is the ratio of the central mass to the 4 orbiting masses, you can compute the linear stability by finding the characteristic polynomial of a 16x16 matrix given by Hamilton's equations
[tex] \dot{p_i} = \frac{\partial H}{\partial x_i}[/tex]
[tex] \dot{x_i} = \frac{\partial H}{\partial px_i}[/tex]
(The above eq's need to be duplicated for y) - with the appropriate initial conditions for all the [itex]x_i,y_i,px_i,py_i[/itex] which represent the initial state of the system.
This is obviously something that you don't want to try by hand.
Here w^2 = M + 1/4 + sqrt(2)/2
The characteristic polynomial looks like
1/8192*(256*x^8+512*x^6*M+256*x^6+256*x^6*2^(1/2)+
256*x^4*M^2+640*x^4*M+1408*x^4*M*2^(1/2)+736*x^4+
320*x^4*2^(1/2)+384*x^2*M^2+1152*x^2*M^2*2^(1/2)+
2400*x^2*M+960*x^2*M*2^(1/2)+592*x^2+624*x^2*2^(1/2)+
2736*M^2+864*M^2*2^(1/2)+1272*M+1368*M*2^(1/2)+
361+204*2^(1/2))*(4*x^2+4*M+1+
2*2^(1/2))*(8*x^4+4*x^2*2^(1/2)+
2*x^2+9*2^(1/2)+8*x^2*M+36*M*2^(1/2))*x^2
which appears to have no real or imaginary parts for M = 100, suggesting that the system is (marginally) stable with a central mass. Pertubations should not grow or shrink.
For M=100, the characteristic polynomial is
1/8192*
(256*x^8+51456*x^6+256*x^6*2^(1/2)+2624736*x^4+
141120*x^4*2^(1/2)+4080592*x^2+11616624*x^2*2^(1/2)+
27487561+8777004*2^(1/2))*
(8*x^4+802*x^2+4*x^2*2^(1/2)+3609*2^(1/2))*
(4*x^2+401+2*2^(1/2))*x^2
Without a centeral mass, the system is not stable for n=4.
The numerical simulations for very high n's with no central mass mentioned are interesting - I haven't done those, though I've seen the results.
They appear to be a system that is linearly unstable, but has limit cycle oscillations, which implies a non-linear sort of "stability".
[add]
ps - adding the central mass terms to the Hamiltonian was a bit of an afterthought, I may have to review how I did this :-(.
  • · Replies 21 ·
