Relationship between Temperature & Half-Life
The discussion explores the relationship between temperature and the half-life of a radioactive element, considering various temperature conditions and their potential effects on radioactive decay. Participants examine theoretical implications and the underlying physics, including atomic motion and nuclear forces.
  • Some participants propose that temperature might not affect the half-life of a radioactive element, arguing that radioactivity is governed by nuclear forces rather than atomic motion.
  • Others suggest that higher temperatures could introduce relativistic effects that might minutely alter the half-life due to increased atomic velocities.
  • One participant posits that radioactive decay rates could decrease in colder environments, suggesting that at absolute zero, radioactivity might cease entirely.
  • A later reply questions the assumption that zero Kelvin halts all atomic activity, indicating that nucleonic states may remain unaffected while other atomic interactions, like covalent bonding, are impacted.
  • Another participant notes that extreme temperatures leading to full ionization or significant nuclear reactions would change the definition of half-life, suggesting that under such conditions, half-life measurements would not apply.
Participants express differing views on whether temperature affects half-life, with some asserting no effect and others proposing potential changes under specific conditions. The discussion remains unresolved with multiple competing perspectives.
Limitations include assumptions about the nature of atomic and nuclear interactions at various temperatures, as well as the implications of relativistic effects and extreme conditions on half-life definitions.
Ace Nova
Lets say we have a radioactive element X in a closed environment, if we were to measure the half-life of element X's radioactive decay at:
1) Near absolute zero
2) At room temperature
3) At 1000s of degrees Kelvin
Would there be a change in element X's half-life even if it is minute? And if so which way would it change in relationship to temperature.
Science news on Phys.org
I suspect there is no change due to temperature. Temperature is a measure of atomic motion, while radioactivity depends on forces inside the nucleus itself.
Consider it this way, (probably should have worded this with more SR), I know that Temperature is a measure of Atomic motion. In a higher temperature sample of the same material, atoms are moving around faster than those in a colder one.
Much like we can basically ignore relativity at small velocities and just use Newtonian physics, there is still relativistic effects although they are minute. Couldnt relativity's minute effects change the half life minutely as the average velocity of the atoms increase as temperature increase.
This is a great question!
My thoughts: Since the "event" of radioactive decay is directly and immutably associated with changes in nucleonic states and, since, these changes are directly affected by temperature, it seems reasonable that the rate of radioactive decay is lessened in colder environments.
I would be willing to posit that a gram of plutonium would have zero radioactivity in a zero-degree's Kelvin environment.
mmwave, thanks for the correction on my post. I was obviously under an erroneous assumption that zero-degrees Kelvin halted ALL atomic activity.
So a proton, for instance, would not break down into its associated quarks in a zero-degree Kelvin environment, if I am understanding this correctly. So, as you said, nucleonic states are not affected.
If I am getting all this, would it be fair to suggest that a zero-degrees Kelvin environment affects electrons ONLY; for example, co-valent boding is no longer possible, the material easily disintegrates, but the individual atoms remain intact, including any radioactive events?
Good lesson for me. Thanks.
If the temperature of the radionuclide were high enough that it became fully ionised, and then even higher so that significant numbers of nuclear reactions were to take place, then the 'half-life' would be different. But then you'd have taken the poor old atom way beyond the regime in which 'half-life' is defined.
Ditto re pressure - when crushed to white dwarf densities, the 'half-life' will surely be different. :wink:
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 19 ·
  • · Replies 25 ·
