What is the significance of the Compton wavelength for an isolated particle?
The discussion revolves around the significance of the Compton wavelength for an isolated particle, exploring concepts related to particle collisions, wavefunctions, and their interpretations in modern physics. Participants engage with theoretical implications and the physical meaning of these concepts, particularly in the context of quantum mechanics.
  • Some participants question how point particles can collide given that their distance would be zero, suggesting that collisions may refer to the superposition of their wavefunctions.
  • It is proposed that interactions between charged particles, such as electrons, do not require physical contact due to the influence of coulombic forces.
  • Others note that even neutral particles like neutrinos will have overlapping wavefunctions, leading to interactions that are governed by specific rules.
  • There is a discussion about the nature of wavefunctions, with some participants expressing skepticism about their physical meaning versus their utility as mathematical models for calculating particle behavior.
  • One participant raises the question of whether the Compton wavelength has significance for an isolated particle in its rest frame, suggesting it may only be relevant during interactions.
  • Another participant expresses uncertainty about the physical association of the Compton wavelength, viewing it as a constant potentially linked to energy changes during collisions.
Participants express differing views on the interpretation of wavefunctions and the significance of the Compton wavelength, indicating that multiple competing perspectives remain without a clear consensus.
The discussion includes assumptions about the nature of particles and their interactions, as well as the interpretation of mathematical models in physics, which remain unresolved.
daniel_i_l
How can point particles collide, wouldn't the distance between them be 0 meaning that they're right on top of each other. Or, when we talk about particles colliding do we really mean the superposition of their wave functions? an explanation would be appreciated. Thanks.
1. In many instances, these "point particles" are charge particles, such as electrons. The coulombic forces alone extends beyond the "size" (if there is such a thing) of the particle. So there does not need to be any physical contact for there to be an interaction. Strongly-correlated electron systems in condensed matter deal with this all the time.
2. Even for neutral particles such as neutrinos, at some point, the wavefunction of the particles will start to significantly overlap. When that happens, these particles will sense each other's presence and a whole set of rules starts occurring. This is what we call "interactions".
Zz.
Thanks for the explanation.
One more thing, does modern physics have an explanation of what it means for "wavefunctions" of particles to interact. Aren't WF mathematical models that help us calculate the motion of particles statisticlly but lacking further physical meaning? (sorry for the ignorence, I havn't started learning QM yet). Thanks.
I am not going to get into this "mathematical model" versus "physical meaning" thing that appears to have no end. I will simply say that the wavefunction has allowed us to make amazing description of the relevant system. The materials that you used in your modern electronics are understood via band theory of matter that makes use of "wavefunction overlap" to describe its behavior.
So you decide for yourself if you consider them just nothing more than "mathematical model". Come to think of it, you may also want to consider if Newton's laws and Maxwell equations are also nothing more than "mathematical models" either.
Zz.
Zapper, does the Compton wave length have any real meaning for an isolated particle in its rest frame? It seems to me that it only comes into play when the particle interacts, i.e. emits or absorbs something.
I don't think I've ever associated it with anything physical. It is simply a constant, maybe can be linked to the energy gained by the electron, which is no longer in that rest frame after collision.
Zz.
  • · Replies 36 ·
10K
  • · Replies 17 ·
