Are These Astronomy Calculations Correct?
  • Thread starter Thread starter astronomystudent
The discussion revolves around calculations related to the apparent and absolute magnitudes of stars, specifically focusing on Arcturus and Sirius, as well as general concepts in astronomy related to distance measurements and luminosity comparisons.
  • Mixed
  • Participants are attempting to calculate distances in parsecs and light-years based on given magnitudes, while also questioning the accuracy of certain inputs, such as the distance for a star. There is also a discussion about the significance of precision in astronomical calculations.
Some participants have provided corrections and clarifications regarding the calculations, particularly addressing potential typographical errors in the distance values. There is ongoing exploration of the relationships between absolute magnitude, apparent magnitude, and distance, with some participants expressing uncertainty about specific calculations.
Participants are discussing calculations under the constraints of typical astronomical measurement practices, including the use of significant figures and the implications of the mass-luminosity relationship.
astronomystudent
1. Given that Arcturus has an apparent magnitude of -0.06 and an Absolute magnitude of -0.30, calculate its distance in parsec in light-years.
Answer = 11.17 parsecs & 36.4 light years
2. Given that Sirius has an apparent magnitude of -1.47 and a distance of 2.67 parsecs, what is the Absolute magnitude?
Answer = 1.39
3. Assume that a star has an Absolute Magnitude of -11.7 and a distance of 17-5 parsecs from our solar system, what would be the apparent magnitude as seen from Earth?
Answer = 22.86
Answer = 22.86
The others are fine, but this one looks way off. Did you mean to type "17-5" parsecs?
No, sorry I typed it wrong. It's supposed to be: 1705. Thanks for catching that. Here are the rest of my answers, are the others correct?
1.) distance - 11.17 parsecs
36.41 light -years
2.) m = 1.39
3.) M = 22.86
4.) distance - 46.08 parsecs
150.302 light-years
5.) 2401 times greater than that of the Sun's using L = M^4
3.) M = 22.86
Try this one again. The SDSS survey can see -11th magnitude objects at much more than 1.7 kpc and its limiting magnitudes are usually in the low 20s.
150.302 light-years
Don't know what the questions were for these last two.
3.) m = -.54137808
Here are the other questions:
4.) If the Hubble Space Telescope measure a parallax angle of 0.0217 arcsec for a given star, how far away from us is it in parsecs and light-years?
5.) If a star has a mass seven times greater than our Sun, what is the luminosity of the star compared to our Sun?
3.) m = -.54137808
They all look right, but in general, it's a bad idea to quote a lot of significant digits in astronomy. On that last problem, in particular, the mass-luminosity relationship is very approximate.
