What Angle Should a Cannon Be Set to Hit a Target 400m Away and 30m Above?
  • Thread starter Thread starter Superman2
    Angle Release
The discussion revolves around determining the angle at which a cannon should be set to hit a target located 400 meters away and 30 meters above the ground, given an initial projectile speed of 100 m/s. The problem involves projectile motion equations and requires solving for the angle of launch.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the use of horizontal and vertical motion equations to relate distance and height to the launch angle. There are attempts to express time in terms of the angle and to manipulate the equations to isolate the angle.
Some participants have successfully derived expressions for the angle, while others are clarifying details about the variables involved, such as time. There is an acknowledgment of the complexity of the algebra involved in solving for the angle.
Participants mention the need to consider the height of the cannon and the assumptions made regarding the initial conditions of the projectile motion. There is also a reference to external resources that may provide additional context or solutions.
Superman2
A cannon that shoots projectiles at 100m/s must hit a target 400m away and 30m above the ground. What angle must the cannon point at in order to hit the target?
I have two functions:
x = V*cos(theta)*t, where V = initial velocity, and
y=V*sin(theta)*t - (g*t^2)/2 where g = gravity's acceleration
but i can't solve for theta.
can somebody help me?
Why can't you solve for theta?
Since you are trying to hit a target 400 m away with initial speed 100 m/s, the horizontal equation, x = V*cos(theta)*t, becomes
400= 100 cos(theta)t or t= 40/cos(theta).
Since the height of the target is 30 m above the ground (which, I assume, is the height of the cannon), the vertical equation,
y=V*sin(theta)*t - (g*t^2)/2, becomes 30= 100 sin(theta) t- (g t<sup>2</sup>)/2. Now using t= 40/cos(theta), we can write that as 30= 4000 (sin(theta)/cos(theta))- 800g/cos<sup>2</sup>(theta).
Multiplying both sides by cos<sup>2</sup>(theta),
30 cos<sup>2</sup>(theta)= 4000 sin(theta)cos(theta)- 800g
That's a little complicated but can be solved.
thanks
cool i solved it, it was pretty damn long
hmm
great :) this kinda answeres the first part of my question earlier...
er
:| just one question... the variable t in that equation is time... correct?
hmm
ok... well this kind of explains a few things about designing the trajectory of a bullet fired from a weapon at a given angle. let me see if i have this right.
If a bullet is fired at a specific angle and muzzle velocity then it would be at point x and y which can be derived from the equations at time t right?
like if V = 1200 m/s and angle of fire is 60* then the bullet would be at point (12000, 18824) right?
The solutions in the beginnins solve different stuff including t i think.
in the last solution, if the bullet initial velocity is 1000m/s and the target is at point (3000, 4000) then, the equation solves the firing angle.
Its a little hard to explain what it does but here's a tip. read it over 3-4 times and ull prob get it.
so basically it solves for theta in the equations x = (Vx)t, and
y = (Vy)t + (1/2)at^2
so first it solves algebraicaly for t in the first equation which becomes t = x / (Vx), which is 3000m/Vx or 3000m/(1000cos(theta))
then it substitutes it for t in the second equation in the third line of the solution.
then it reduces it in the fourth line, then multiplies both sides by cos^2(theta)
then it reduces again which results in the fifth line and then
substitutes sin(theta) for sqrt(1 - cos^2(theta))
then after squaring both sides and reducing the equation becomes a second degree one like ax^2 + bx + c = 0 , where x is cos^2(theta)
then it uses the quadric formula
x = ( -b -+ sqrt(b^2 - 4ac) ) / (2a) to find cos^2(theta) then from there its easy it find the square root of the answer and then finds the cos-1 of the answer to find theta;
lol that's long, a friend told me there's a much easier way in advanced physics school books.
  • · Replies 38 ·
