Differential equation- (haven't had any courses on diff. equations yet
The discussion revolves around solving a differential equation related to reaction kinetics, specifically the equation \(\frac{dC}{dt} = -k C^n\) with an initial condition \(C(0) = C_0\). The original poster expresses a lack of prior knowledge in differential equations, as they have not yet taken a course on the subject.
  • Participants discuss the method of separation of variables and integration techniques. There are attempts to derive expressions for \(C\) as a function of \(t\) and questions about the correctness of integration results. Some participants express confusion about applying initial conditions and how to plot the function to obtain a straight line.
Several participants have provided guidance on integration and the implications of the initial condition. There is an ongoing exploration of how to express \(C(t)\) and plot it correctly. While some participants have made progress, there is still uncertainty regarding the final form of the function.
The original poster is under time pressure to complete the problem before a deadline, which adds to the urgency of the discussion. There are references to specific values of \(n\) affecting the integration process, and the conversation includes informal remarks about planning and timing related to personal events.
Lisa...
Differential equation- please help (haven't had any courses on diff. equations yet :(
Hi!
I need to solve this differential equation:
[tex]\frac{dC}{dt} = -k C ^n[/tex]
with C(0)= C0
for n= 0, 1, 2, ...,
Then I need to plot C(t) as a function of t in a way in order to obtain a straight line.
(This is used for reaction kinetics)
The only problem is that I haven't had a course on differential equations yet (it is planned for next month), yet I have to solve this problem before tomorrow...
Could anyone of you be able to help me? I'd be very very grateful!
Use the method of separation by parts, its usually the first topic taught in a Diff. Eqn. course. Try grouping C^n with dC and k with dT. Then integrate, not forgetting to add the constant of integration, this is where the intial conditions will come to play.
Thanks, I find:
[tex]= \frac{dC}{C^n} = - k dt[/tex]
integrating gives:
[tex]\frac{1}{ln C} C^n = -kt + A[/tex]
with [tex]A = \frac{1}{ln C} C^n[/tex] so
[tex]\frac{1}{ln C} C^n = -kt + \frac{1}{ln C} C^n[/tex] ??
But how do I find C as a function of t ?!
[tex]\frac{1}{ln C} C^n[/tex]
is not correct.
What's
[tex]\int \frac{dC}{C^n}[/tex] when [itex]n \neq 1[/itex].
Oh I see... I've considered C n to be of the form g x (an exponential function).
Though it should be - 1/(n-1) Cn-1 if n is NOT 1 and if n=1 (cause n most certainly can be 1) it should be of the form: ln C
is that correct?
-n/Cn+1 is not right
An easy way to check is to differentiate your answer. For example, if you differentiate -n/Cn+1, you get n(n+1)/Cn+2 which isn't what you need.
How about now?
I guess I'm mixing integration & differentiation up again ... just blame it on being tired :P
Yes, it's right now. That's why I don't do my homework late in the night when I'm tired :smile:
But now that I have
- 1/(n-1) Cn-1 = -kt + A if n is NOT 1
ln C = -kt +A if n =1
how on Earth would I get a function for C(t)?! + I don't get how I can put the initial condition C(0)= C0 into the equation... if I choose t=0, it gives me respectively:
- 1/(n-1) Cn-1 = A
ln C= A
You need to plot C(t) as a function of t in a way in order to obtain a straight line, right?
So your answer is right there! When you plot a graph of [tex]\frac{-1}{(n-1)C^{n-1}}[/tex] (on the y-axis) vs [itex]t[/itex] (on the x-axis) or ln C vs t when n=1, you have a straight line
To use the initial condition, put C(0) = C0, not C.
So, you relation will be - 1/(n-1)C0n-1 = A and ln C0 = A
OMG that's too easy :D Thanks a lot for helping me out!
Sorry for my poor planning btw, but yesterday was Queens Day, so I could not resist going to town ;)
You're welcome. But, I thought the Dutch celebrate it on the 30th (ie, today)?
Very good of you, that's true!
But the 30th (today) is on a Sunday and because the queen is Christian and there's a Christian holiday on this Sunday (it has something to do with thanking the Lord for having our crops or something like that) she decided to make an exception and celebrate it a day earlier.
  • · Replies 20 ·
