How to Calculate Mass of C6H5NO2 from Given Reactants?
The discussion revolves around calculating the mass of C6H5NO2 produced from the reaction of C6H6 with HNO3, given a 70% yield. Participants explore the stoichiometry of the reaction and the implications of yield on the expected mass of the product.
  • Homework-related
  • One participant outlines the method for calculating the number of moles of C6H6 and how to apply the yield to find the moles of C6H5NO2 produced.
  • Another participant provides a step-by-step calculation, confirming the moles of C6H6 and applying the yield to find the moles of C6H5NO2, ultimately calculating the mass of the product.
  • A separate question is raised regarding a different reaction involving Hg(NO3)2 and Na2S, asking if the same method applies, indicating a need for clarification on the concept of formula units.
Participants generally agree on the method for calculating the mass of C6H5NO2 based on the yield and stoichiometry, but there is no consensus on the second question regarding HgS, as it introduces a new concept that has not been fully addressed.
The discussion does not clarify the definitions of "formula units" or how they relate to the calculations presented, leaving some assumptions unaddressed.
Students or individuals interested in chemical reactions, stoichiometry, and yield calculations in chemistry.
Aya
the folowing reaction proceeds with a 70% yeild
C6H6 + HNO3 = C6H5NO2 + H2O
calculate the mass of C6H5NO2 expected if 12.8g of C6H5 reacts with excess HNO3
How do you do this problem?
I'm no expert, but this was what I think:
The number of moles of C6H6 can be calculated (mass/Mr), and since 1 mole of reactant produces 1 mole of product and the reaction is only 70% "efficient", means that the number of moles of the product is 0.7 times the number of moles of the C6H6, and so from this, simply multiply by the Mr of the C6H5NO2 to get the result.
btw, the excess bit tells you that all 12.8g of C6H6 reacts.
^ Thanks
#mols of C6H6
n=m/M
n=12.8g/78.06g/mol
n=0.164mol
#mols of C6H5NO2
=0.164mol(0.70)
=0.1148mol
mass of C6H5NO2
m=nM
m=0.1148mol(123.06g/mol)
m=14.1g
Like this?
and I have another question
If 3.45 x 10^23 formula units of Hg(NO3)2 are reacted with excess of Na2S, what mass of HgS can be expected if this process occurs with 97% yield?What are fomula units?
you would do that question the same way as the previous one right?
  • · Replies 16 ·
27K
