What is the convention for defining polarization direction in EM waves?
The discussion centers on the convention for defining polarization direction in electromagnetic (EM) waves, specifically addressing the effects of polarizers on light intensity. When unpolarized light passes through a polarizer, the intensity is halved, as per the Law of Malus, which states that the intensity of polarized light is proportional to the cosine squared of the angle between the light's polarization direction and the axis of the polarizer. The conversation also touches on the confusion regarding the intensity reduction through multiple polarizers and the conventions used to define polarization, particularly whether polarization is aligned with the electric (E) or magnetic (M) field in EM waves.
  • Understanding of the Law of Malus in optics
  • Basic knowledge of electromagnetic wave properties
  • Familiarity with the concept of light polarization
  • Awareness of the effects of polarizers on light intensity
  • Research the mathematical formulation of the Law of Malus
  • Study the properties of electromagnetic waves, focusing on electric and magnetic fields
  • Explore the practical applications of polarizers in optics and photography
  • Investigate the historical context of polarization conventions in physics
Physicists, optical engineers, students studying electromagnetism, and anyone interested in the principles of light polarization and its applications.
UrbanXrisis
I have a quick question about polarization. When I put a polarizer up an unpolarized source, say the polarizer blocks all the polarization in th y direction and so all the photons in the x direction comes out of the polarizer. Is the intesity halved?
It seems to me that the intensity should be halved, however, as described in http://hyperphysics.phy-astr.gsu.edu/HBASE/phyopt/polcross.html#c2"
why isn't the polarization of the of the three polarizers 1/6 the regular intensity instead of 1/4 as it describes in the example?
Follow the “Law of Malus” at the same web site.
After the light is polarized by filter 1 and then filter 2
Malus says 1/2 get though – and will be aligned with #2
Filter 3 is 45o off from #2 so again
Malus says 1/2 get though – now aligned with #3
1/2 times 1/2 gives the 1/4 they were talking about
BUT remember they are comparing to the light coming though filter 1
NOT the original light.
Compared to the original assumed un-polarized source it would be 1/8.
Because, Yes the first filter removed 1/2 the light.
Another simple one:
Polarized glasses set their polarization H or V to block predominate glare caused by reflected off flat surfaces like water.
So what is the convention for defining polarization between Horizontal and Vertical?
Are Sunglasses polarized V to allow V light though, thus blocking H glare?
OR is glare V thus Sunglasses are polarized to H so that V is blocked?
What is the polarized direction aligned with in the EM wave, the E (Electric) or the M (Magnetic)?
A matter of convention - just what is the convention?
Maybe someone even knows how the convention was established.
Example: Ben Franklin or those of his time a generally credited with establishing the charge polarity convention that resulted in the electron being defined as “-" not “+”.
  • · Replies 16 ·
