How Can We Ensure Only One Particle is Emitted in the Double Slit Experiment?
The discussion revolves around the double slit experiment in quantum physics, specifically focusing on how to ensure that only one particle is emitted at a time during the experiment. Participants explore the implications of this condition for the observed interference patterns and the reliability of detection methods for single photons.
  • Some participants question how to be certain that only a single particle is emitted at a time, suggesting that there may be a high degree of uncertainty in such measurements.
  • Others argue that detection methods can confirm the emission of one particle at a time, with the resulting interference pattern emerging from many such emissions.
  • A participant proposes that the nature of quantum physics might imply a risk of simultaneous emissions due to the mechanisms of photon production, likening it to a bank of capacitors.
  • Some participants discuss the reliability of devices that can detect single photons, noting that calibration and testing are essential for ensuring accurate measurements.
  • There is mention of using low power outputs and various filtering methods to reduce the likelihood of multiple photons being emitted simultaneously.
  • One participant references entanglement experiments as a context in which single photon detection is critical, highlighting the statistical nature of photon emissions.
  • Another participant asserts that single photon detection is routinely achieved and can be calibrated to high accuracy, referencing specific studies to support this claim.
  • Concerns are raised about the acceptance of experimental conditions that allow for a high probability of multiple photon incidents, suggesting that careful control is necessary.
Participants express a range of views on the certainty of single particle emissions and the effectiveness of detection methods. While some agree on the reliability of current technologies, others remain skeptical about the potential for simultaneous emissions, indicating that the discussion contains multiple competing perspectives.
Participants highlight limitations related to the assumptions made about photon emissions and the conditions under which experiments are conducted. There is also a recognition of the statistical nature of quantum events and the challenges in ensuring precise measurements.
This discussion may be of interest to those studying quantum physics, particularly in the context of experimental design and the interpretation of results from the double slit experiment.
jeffceth
I have an advanced amateur's(if there is such a thing) grasp of the concepts of quantum physics. However, the typical usage of the 'double slit experiment' to explain an observation of the differences between classical and quantum behaviours confuses me.
The specific case, of course, is when only a single particle is shot at the two slits and yet, over time, a compendium of such cases will retain the pattern of cancellation and reinforcement found with a large number of 'simultaneous' particles. My question is this: how can we, in fact, be sure that only a single particle is being emitted at a time in our experiment? Presumably there would be a high degree of uncertainty associated with such a precise declaration, wouldn't there?
For the record, I happen to think quantum theory is a pretty good approximation of our observed phenomena, I just don't completely understand this example.
sincerely,
thatwouldbeme
No, you would detect one particle at a time. The pattern that results from many particles then shows the interference.
This is an example of what DrChinese is describing.
http://www.optica.tn.tudelft.nl/education/photons.asp
We can deduce that one photon passes through at a given time from the calculation of how many photons are there per second and, on avarage, the separation between them. Since the equipment is not several kilometers long by orders of magnitude, it is a safe bet that on average, one has only one photon at a time passing through the slits.
Zz.
Zz.
I understand that we can calculate the average distance between photons and suppose it is the actual distance, but wouldn't the nature of quantum physics itself suggest that because in whatever medium the photons are being produced it requires a minimum charge to release a photon at all we essentially have the equivalent of a huge bank of capacitors charging up and releasing, which might tend to drastically increase simultaneous emissions if the energy source had any sort of wave period to it? Generally speaking, what sort of mechanisms might one employ to reduce the possibility of such an effect?
sincerely,
thatwouldbeme
p.s. DrChinese: do we really have devices that will reliably detect a single photon? In practice it seems we usually have to use a photon multiplier in order to measure what we suppose to be single-photon events.
I have no idea what you just said. If I use a laser (which is what is used in the experiment that I cited in the link), where is the "bank of capacitors" here?
Zz.
Basically you’re questioning the ability of experimentalist’s hardware capabilities. To be sure they test them to build reliable methods. Low but uniform power output - into Filter densities and or crossed polar filters to bring the photon rate down. Lots of test exposures or Detector counts to confirm they can reliably produce one photon per some unit of time, whatever. Statistically you may have a chance of two coming close together. To avoid that issue, the problem becomes how fast can you send them to avoid having two come out together. After all it can be a long slow tedious work made worse if you insist on say one photon per minute. You want the highest rate that still works correctly by never sending two at once. Theoreticians need to trust the experimenters, and they do that by verifying the work. And even then getting it repeated by someone else.
Detecting a single photon?
As you say you have a grasp of the concepts of quantum physics, then you must know some about entanglement experiments. Those very much depend on testing correlations of detections of individual photons or particles don’t they?
Oh, absolutely. They can be calibrated to extremely high accuracy. In fact, entanglement is now routinely used to actually assist in detector calibration and analysis of detector efficiency and accuracy because of experiments like this one:
P. Grangier, G. Roger, and A. Aspect, "Experimental evidence for a photon anticorrelation effect on a beam splitter: A new light on single-photon interferences," Europhys. Lett. 1, 173-179 (1986).
To quote the authors: "A single photon can only be detected once." Using PDC, this is done routinely these days; check out this PDF of an undergraduate experiment that replicates the above: http://marcus.whitman.edu/~beckmk/QM/grangier/Thorn_ajp.pdf . To many standard deviations of accuracy, individual photons are detected within time windows that support theoretical predictions. Check out the article to see how this is done. There are articles out there - I don't have a reference at my fingertip - that explain in greater detail how manufacturers rate their detectors and insure that they perform as described.
Of course, entanglement. Yeah, I should have known that. I pretty much should have been able to answer that myself. Thanks for taking the time though, guys! I guess ultimately even with a high probability of multiple photon incidents the highest cancellation zones would still fail to get pretty much any hits, where as we would expect a large number of the single-photon cases to hit there otherwise, so it doesn't take a whole lot to produce a statistically significant result in that way, too.
jeffceth said:
even with a high probability of multiple photon incidents the ...
I doubt a good experamenter would accept that, and would only use a very low probability of multiple photons.
  • · Replies 24 ·
  • · Replies 36 ·
10K
  • · Replies 42 ·
  • · Replies 33 ·
  • · Replies 17 ·
  • · Replies 16 ·
