Is the Sum of a Geometric Series Always Equal to 2?
The discussion revolves around the sum of a series given by the expression \(\sum_{n=0} ^{\infty} \frac{2n+1}{2^n}\). Participants are exploring whether this series can be classified as a geometric series and how to correctly compute its sum.
  • Conceptual clarification, Problem interpretation, Assumption checking
  • One participant attempts to break the series into sub-sums and applies differentiation to find the sum. Others question the correctness of this approach and the classification of the series as geometric.
There is an ongoing debate about the validity of the original poster's method and the classification of the series. Some participants offer corrections and hints for re-evaluating the approach, while others express confusion about the original reasoning.
Participants are discussing potential errors in the manipulation of the series and the assumptions regarding convergence. There is a lack of consensus on the classification of the series as geometric.
Mathman23
Hi Folks,
I have this here geometric series which I'm supposed to find the sum of:
Given
[tex]\sum_{n=0} ^{\infty} \frac{2n+1}{2^n}[/tex]
I the sum into sub-sums
[tex]\sum_{n=0} ^{\infty} 2^{-n} + \sum_{n=0} ^{\infty} \frac{1}{2}^{n-1}[/tex]
taking [tex]2^{-n}[/tex]
Since [tex]x^n[/tex] converges towards 1/1+x therefore I differentiate on both sides
[tex]1/(1+x)^2 = \sum_{n=0} ^{\infty} n \cdot 2^{-n} x^{n-1}[/tex]
I multiply with x on both sides and obtain
[tex]x/(1+x)^2 = \sum_{n=0} ^{\infty} n * 2^{-n} x^n[/tex]
if I set x = 1 on both sides I get
[tex](1/4) ? = \sum_{n=1} ^{\infty} n*2^{-n} = 2[/tex]
My teacher says that the expression has to give 2 on the left side, and not (1/4).
What am I doing wrong? Any surgestions?
Best Regards
Fred
Your first line is wrong. When you break your sum up into two sums, you don't do it right. Also, when you say xn converges towards 1/1+x, I suppose you mean [itex]\sum x^n[/itex] converges to 1/1+x. However, this is wrong, it converges to 1/1-x. After that, I have no idea what you're doing. I don't know where you're getting the "=" sign from. Sorry, I think just about everything in your post makes no sense.
is not a geometric series!
Mathman23 said:
Hi Folks,
Given
Best Regards
Fred
Firstly, you separated the sum wrongly. Here's the correct version :
[tex]\sum_{n=0} ^{\infty} \frac{2n+1}{2^n} = \sum_{n=0} ^{\infty}(n.2^{1-n})+\sum_{n=0} ^{\infty}(2^{-n})[/tex]
Hint : For the first part-sum on the RHS, try dividing by 2 then subtracting away from the original part-sum.
Actually, it works out to be one ! :biggrin:
