Will Changing the Air Column Length in a Pipe Create Resonance in Helium?
The discussion revolves around the phenomenon of resonance in a pipe filled with helium, where the length of the air column can be adjusted. Participants explore how the speed of sound in helium, which is significantly greater than in air, affects the resonant lengths of the pipe.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the relationship between the speed of sound in different gases and the resulting wavelengths and frequencies in a closed-end pipe. There are attempts to derive the first three resonant lengths based on the wave equation and the properties of sound in helium versus air.
The conversation includes various approaches to calculating resonant lengths, with some participants providing formulas and others questioning the completeness of the original problem due to missing frequency information. There is an ongoing exploration of how resonance lengths in air relate to those in helium.
Some participants note that the problem may lack sufficient information, particularly regarding the frequency of the sound source, which is necessary for calculating specific resonant lengths.
jimmy_neutron
Here's the situation: you have a pipe in a bucket of water and can vary the length of the air column in the pipe by raising or lowering it.
Here's my question, hope someone can help.
The speed of sound in helium is three times greater than the speed of sound in air (340m/s). Under these conditions will there be any resonances as you change the pipe length. If so what lengths of the pipe will give you resonances (first three resonant lengths).
Where do I get started? thanks!
The frequencies possible in a pipe closed one end are
f = nv / (4l)
n is an odd number (1,3,5,...)
So for first three resonant freqs. you have to put the value of n as 1,3,5 respectively and solve.
Using the basic wave equation
[tex]v=\lambda f[/tex]
The wavelength in air will be
[tex]\lambda_a=\frac{v_a}{f}[/tex]
The wavelength in helium gas will be
[tex]\lambda_h\frac{v_h}f}[/tex]
which comes to
[tex]\lambda_h=\frac{3v_a}{f}[/tex]
therefore the wavelength in helium will be three times of that in air
[tex]\lambda_h=3\lambda_a[/tex]
Now as you raise the pipe resonance will form when its length is equal to one quarter of a wavelength [itex]l=\frac{\lambda}{4}[/itex], the next resonance will form as the pipe length can hold what fraction of the wavelength?
Ok, so for the first resonance it will be wavelength/4
For the second resonance (the third harmonic) it will be 3x wavelength/4
And for the third resonance it will be 5x wavelength/4
How do I find the wavelength in order to calculate the length of the pipe?
thanks.
thanks.
If you are looking for numerical values of lengths, you are stuck. It seems to me that the question is incomplete. Are you sure they don't provide the frequency of the source of sound?? Without that, you can't answer the question! (if they give the speed of sound, this suggests that they must have given the frequency somewhere)
One can conclude from the wave equation
that if the frequency changes the wavelength will change and therefore the length at which standing waves will form, no matter in which medium you perform the experiment. All one can say from such an analysis is how the resonance lengths in air will relate to those in helium. I assume that since the lengths in air is known according to the formulas to be
[tex]l_1=\frac{\lambda}{4}[/tex]
the corresponding length for the same frequency in helium will be
[tex]3l_1[/tex]
see if you can find the other two in terms of [itex]l_1[/itex]
13K
