| Thread Closed |
Attaching two springs together |
Share Thread | Thread Tools |
| May4-06, 08:03 PM | #1 |
I have a question on a recent assignment.
A weightless spring is stretched 10 cm by a suspended 1-kg block. If two such springs are used to suspend the block, one spring above the other, to effectively provide one double-length spring, then the total stretch of the double-length spring will be? Is the k constant the same in both cases? Thank You, Sean |
| May4-06, 09:13 PM | #2 |
Admin
Each spring experiences the same force since they are colinear. |
| May5-06, 12:58 AM | #3 |
If each spring experiences the same force, 1-kg, then each will have a 10 cm strech and total 20 cm combined?
| May5-06, 02:14 AM | #4 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: Attaching two springs together
| Electrically attaching to Aluminium | Materials & Chemical Engineering | 6 | ||
| Attaching a LED to the comp power supply | General Engineering | 5 | ||
| Attaching conductive cable to orbital object | General Physics | 6 | ||
| Attaching hard drive? | Computing & Technology | 5 | ||
| Attaching Plastic | Materials & Chemical Engineering | 5 | ||
